Go to Post I don't need sleep, just more Mountain Dew. Oh, and a muffin. - hallk [more]
Unread 04-12-2006, 13:16
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Re: pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
Originally Posted by Jeremiah H
Very interesting, indeed.
I am not familiar with the concept of ball lockup shifting gearboxes, indeed this is the first I have ever seem of them. I am in charge of developing a godd two-speed gearbox for '07, so here are my questions (more will follow after this) Your expertise and help is greatly appreciated.
I understand how the balls are pushed into slots in the gears, but what is it that causes the thus engaged gears to turn the output shaft? In a dog shifter gearbox, the dog is positively engaged on the shaft (still allowed to slide) and so whatever gear the dog is locked into thus turns the shaft. I cannot find any such mechanism in this drawing. Perhaps I am missing something, but I think this is an important consideration.
And, following that, what happens to the gear (with its ball slots) when it is disengaged and must freewheel on the output shaft? My understanding of the design at present leads me to believe that it would bounce and chatter considerably, possibly even locking the entire gearbox up if it doesn't properly disengage.
Just my thoughts, if someone can answer them, I would greatly appreciate it. Thank you in advance. -JH
The balls are what cause the engaged gears to turn the output shaft. Comparing this to a "dog shifter" the balls are your dogs. Half or more of the ball remains in the shaft and the other half goes into the slots in the gear. two things can happen when the balls are disengaged. They depend on the design. The original hodaka design had a small groove in the gear and used the balls to act like a ball bearing when not engaged this means the balls stick out from the shaft a couple thousandthsand the gear rides on the balls. For simplcity we have not put this groove in our design. As Brad stated we leave between 4-10 thousandths of air gap between the shaft and the gear. In our design the balls fall flush into the shaft. Then all we do is use a thin oil/grease mixture to lubricate the gears and shafting. The gears have some space to move on the shaft, but not as much space as it seems you are getting at. Also we have never had the transmissions jam up. I don't have time to look for it, but we have produced a white paper on this type of shifting and feel free to PM myself or team222badbrad with any questions.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 05-12-2006, 03:45
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
How The Ball Lock Transmission Works:
Ball Lock
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 05-12-2006, 20:53
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
Awesome video badbrad!! It explains the transmission very nicely. One question: How deep do the slots for the balls in the shifting gears go? A full 5/32? Or less than half of the bearing. It seems that slightly less would be the way to go, maybe 1/4 inch deep into the gear with a 5/16" EM (our design uses 5/16" bearings as well). I would think that the balls would disengage easier.
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Unread 08-12-2006, 14:38
AKA: Bradley Rigdon
Sorry for taking so long to get back to you.
How far the balls will protrude out of the shaft depends on the diameter of your "Ball Plunger" + two times the diameter of your balls - the diameter of your shaft.
If your plunger is .515" and your balls are .3125", then your slots must be atleast 1.14" from tip to tip. Each ball upon being "Locked" would travel .07" above the shaft if your shaft is 1".
1/4'' = VERY BAD!!! If your balls were to travel past halfway above the shaft your shifting transmission would then become a single speed or perhaps shred to pieces. The balls would become trapted between the gears slots and shaft because of the rotational forces you put on them.
This attachment should help you out.
77 thousands is plenty as thats what the motorcycle transmission I used in the video had.
Unread 18-12-2006, 21:18
FRC #0948
Ah, thanks very much for the warning!!!
There is a very good chance you'll be seeing a transmission like this on NRG's robot this year... we talked to our machine shop about it a week or so ago, and they were very optimistic about the design.
-Jake Felser-
Team 33's 2004 gearbox CAD files AdamHeard Inventor 1 03-10-2006 19:07
pic: My First time.....(CAD car drawing) negfrequency Extra Discussion 13 26-06-2006 23:12
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
