Go to Post Nascar was one of the first things i though when the unveiled this years competitions...... silly left turns... they hurt right turns feelings :rolleyes: - Miniflash [more]
Unread 05-12-2006, 01:12
Re: pic: Team 948 2 speed dog shifter
My suggesstion: Put a shifting rod through the output shaft to avoid having the clyinder offset. Anyway, looks good.
Unread 05-12-2006, 07:54
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I like how compact this is. It would need additional reduction on the output to be useable as drive. Generally the majority of the reduction is performed before the shift shaft to reduce the torque on this additional reduction.
As it is, I am guessing that low speed has an output of 687 rpm and high is at 2750 rpm. This ratio (4:1) requires some thinking on strategy - Do you want a real slow low gear with a controllable high speed or a reasonable slow speed with a almost out of control high speed. We had the latter in our first two speed. The students called high gear "ludicrous speed". I usually aim for 3:1 in my gearboxes with 300 rpm on an 8" wheel for high speed.
Good luck!
Andy Brockway
Team 716, The Who'sCTEKS
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing jfelser Extra Discussion 24 18-12-2006 21:18
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
Team 948 Animation Released! jfelser 3D Animation and Competition 3 14-02-2006 16:38
pic: Vex 2 Speed Mesh Shifter Matt Krass Extra Discussion 11 17-10-2005 20:58
pic: 948 begins autonomous CD47-Bot Extra Discussion 5 21-03-2004 16:26
