Go to Post Oh the wonders that happen in Michigan competitions... ;) - delsaner [more]
Unread 12-07-2006, 01:28 PM
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
pic: Team 701 Mecanum Design View 2
Work Hard, Have Fun, Make a Difference!
Re: pic: Team 701 Mecanum Design View 2
So, you're drilling a hole through a bolt?
Unread 12-07-2006, 01:44 PM
Bengineer
2, actually.
Come on Tom, you can't tell me that the Cyberknights haven't done that! (I'm sure GUS has done it.)
BEN
Unread 12-13-2006, 07:27 PM
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
Assuming everything fits snugly how are you going to tilt the gearbox forward, the two vertical bolts will move forward when you tilt the tranny down and not line up with the bottom bolt (??) I guess you will oversize the holes in the threaded rod???
Team 701
Unread 03-06-2007, 02:02 AM
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Actually no, you would certainly want to use a piece of shaft and just thread that. It's tedious, I know, but it gives the strength you want with something holding your gearbox.
Salik, I'm thinking both of the shafts would be allowed to rotate, the gearbox should tension nicely if everything is lined up to begin with.
pic: Team 701 Mecanum Design View 1 Doug G Extra Discussion 11 12-13-2006 03:21 AM
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 11-22-2006 09:21 AM
701 Design Alekat Robot Showcase 5 02-01-2006 01:40 AM
pic: Team 226 side view CD47-Bot Robot Showcase 8 02-25-2004 04:25 PM
pic: Team 271's Side View CD47-Bot Robot Showcase 1 03-17-2003 06:48 PM
