Go to Post Generally, when you do something stupid and unsafe, it isn't the best idea to go and tell thousands of people on CD about it. :rolleyes: - Cory [more]
Unread 08-12-2006, 14:38
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
Originally Posted by jfelser
Awesome video badbrad!! It explains the transmission very nicely. One question: How deep do the slots for the balls in the shifting gears go? A full 5/32? Or less than half of the bearing. It seems that slightly less would be the way to go, maybe 1/4 inch deep into the gear with a 5/16" EM (our design uses 5/16" bearings as well). I would think that the balls would disengage easier.
Sorry for taking so long to get back to you.
How far the balls will protrude out of the shaft depends on the diameter of your "Ball Plunger" + two times the diameter of your balls - the diameter of your shaft.
If your plunger is .515" and your balls are .3125", then your slots must be atleast 1.14" from tip to tip. Each ball upon being "Locked" would travel .07" above the shaft if your shaft is 1".
1/4'' = VERY BAD!!! If your balls were to travel past halfway above the shaft your shifting transmission would then become a single speed or perhaps shred to pieces. The balls would become trapted between the gears slots and shaft because of the rotational forces you put on them.
This attachment should help you out.
77 thousands is plenty as thats what the motorcycle transmission I used in the video had.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 18-12-2006, 21:18
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
Ah, thanks very much for the warning!!!
There is a very good chance you'll be seeing a transmission like this on NRG's robot this year... we talked to our machine shop about it a week or so ago, and they were very optimistic about the design.
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Team 33's 2004 gearbox CAD files AdamHeard Inventor 1 03-10-2006 19:07
pic: My First time.....(CAD car drawing) negfrequency Extra Discussion 13 26-06-2006 23:12
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
