Re: pic: 6WD Module
If welded / screwed together properly it should not break all that easily. I Like that design and have another question. The Drive System seems to be well organized and hopefully built but what about the many other modules this robot will have, will there be enough space inside the robot to do a motor transplant w/o having to move anything out of the way? Is the CIMs easy to get to? Will other modules be easily able to be gotten to? If not will all the other modules be modular so that they can be taken out quickly and easily with little to no hassle?
Re: pic: 6WD Module
Looks nice and compact! I've always loved these double plate designs, something we've yet to integrate into one of our robots.
As I understand it, there are two chain runs that go over the motors? How much clearance do you have b/w the chain and the motors? Are you concerned about a) tensioning the longest run b) having the chain (even properly tensioned) slapping against the motors? The hex shaft is nice as well. How are you adapting the sprockets to the shaft, as it looks as though the sprockets are either AM's, or kit sprockets. Neither of which come with a bore you could use. Finally, I'm calculating about 6.5ft/sec, right around the kitbot speed. Have you found this to be a good balance b/w speed and torque? BEN |
Re: pic: 6WD Module
Of course, there's also a pretty big advantage to repairability and that sort of thing as well. In the short time we've done this, we've not had to replace an entire module, but I'm sure that we'd need to as soon as we abandon this design ![]() Quote:
Re: pic: 6WD Module
Madison, we are quite impressed with the idea of removable six wheel modules, and have begun to think about the design of one.
My question is, how to you intend to attach the modules to your frame? I've considered welding angle onto the outside frame, angle onto the modules, bending tabs, etc., but I'm not completely pleased with these methods of attachment. We intend to use 1x1 tube, in the kitbot arrangment style- perhaps even the kitframe, and I run into problems intersecting gearboxes and motors with necessary frame members, just in my head. |
Re: pic: 6WD Module
Madison,
As Andrew said, We have been developing a similar drive train, but are wondering how much each of your modules will weigh completed. As is, A completed frame with our currently designed module will weigh about 35-40 lbs, with each module weighing 15 -20 lbs. Is this comparable to yours? Also, our current design differs from yours in that we will attach the modules directly together using aluminum tube, and that will form our primary Frame. Because of this, our modules had to be somewhat more... Robust, and are going to be made of a thicker plate, probably .20-.25 inch. As soon as we have some renderings we will post them, and thanks for your help in advance ![]() -Cody C |
Re: pic: 6WD Module
I think I'd go with more standoffs and thin plate rather than thick plate, but, as always, it all depends on a lot of things that aren't easy to predict and sometimes aren't easy to test for.
Re: pic: 6WD Module
I was planning on seating this design inside a frame of 3x1" aluminum channel, somehow using the spacers and bolts on each end in the scheme to attach it to the frame. I didn't develop it much further than that because I began in on yet another 6WD setup that's integrated wholly into the frame. I'm looking forward to seeing your renderings. I'll likely be putting up some new renderings of the latest 6WD arrangement we've designed later today. |
Re: pic: 6WD Module
Allrighty then, my renderings are up. (as soon as they are approved)
Re: pic: 6WD Module
What are the benefits of a 6WD over 4WD?
#10
Re: pic: 6WD Module
You get more contact area between the drive wheels and the carpet when you use more wheels.
Some will argue that the reduced weight on each wheel makes it no more effective than a four-wheel system. Others will counter with the idea that the carpet fibers bend and thus have a maximum static friction force they will support for a given area. |
#11
Re: pic: 6WD Module
With this 6 wheel setup with omni wheels in the corners you drag your wheels a lot less on the ground when you are turning in place. With 4 wheels you end up having more motion perpendicular to the wheel which, given a lot of traction in your wheels can really strain your drive train, and make turning much slower.
#12
Re: pic: 6WD Module
I like the removable 6wd modules. Reminds me of something I will be seeing alot of this year.
#13
Re: pic: 6WD Module
hmm yes tom, it kinda does
| pic: Completed Mecanum Module | Madison | Technical Discussion | 9 | 12-11-2006 19:39 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
| 6WD? | Alex Cormier | FIRST Tech Challenge | 14 | 17-04-2006 22:10 |
| pic: 494 Power Module | KEY | Extra Discussion | 14 | 26-01-2005 17:50 |
| pic: Tytus's Coax Crab Module | CD47-Bot | Robot Showcase | 8 | 17-11-2003 10:08 |
