Thread Tools |
Rating:
Display Modes |
Re: USB Joystick adapter is here!
I'm pretty sure most teams would be OK with being somewhere between Division by Zero and Cheesy Poofs!
![]() Last edited by Dennis Jenks : 17-12-2006 at 23:15. |
LOL
You are correct Mike the OI does see a limited value from the controller. We wrote software to translate the variations into "steps" 5 to - 5 and this works fine, this is what we used on our 2006 robot that used to play the whole 2006 on and off season. You are also right about 127 had to program the code so that when it read 127 (unplugged) to send neutral to the motors. Otherwise the robot would take off when the controller was unplugged.
Mike, The big question is are you working with FIRST/IFI to get your adapter legal for competition? If you are working with them have they been receptive to the idea? Last edited by Kingofl337 : 18-12-2006 at 07:01. |
Hey, what kind of answer did you expect from a hardware guy. lol We have been working with IFI. They have been very helpfull. I do not have an answer for you as far as legality. |
Ok, We have updated our user manual. It should be available for viewing tommorow by clicking the tutorials link. The pdf contains an explaination of USB-chicklet, directions for it's use and a list of supported devices. Please let us know if you have any comments or suggestions for improvement. Also available for viewing is a FAQ.
Thank you, Mike Copioli CTRE Hardware Engineer/Developer Team #217 The Thunder Chickens |
Hm...
Why is it so expansive? For an Israeli team each one of those devices will coast about 200$...thats very expansive for such a thing... |
1. Cost of the components to manufacture each device. 2. Availablitity of the components necessary to build the device. 3. Total quantity produced 4. Time and money spent on research and development This is a complicated and unique device. It will allow you to use devices like the X-box controller, wireless and wired Logitech gamepads, The Logitech steering wheel, and numerous USB joysticks. Nothing else like it exists. Now having made that statement, I know someone will try to compare it to similar devices. When doing this one must consider the following: 1. This is an Embedded USB hosting device. That means it does not require an operating system like Windows or Linix. 2. This is not the same thing as a USB to Serial adapter. Serial adapters are not USB hosts. Devices are much less complicated than a Host and require less hardware to build. Yet they are still about 40-50 USD. 3. It performs all of the USB host negotiating and data transfer and then converts it to analog and digital information that is directly connected to the IFI operator interface. We have determined a price that we feel is fair and consistant with the products ability and functionallity. There are good reasons this technology has not existed until now. Think about what it costs to go to a concert, or dinnner at a nice restraunt. In comparison, the cost of this device is not unreasonable. Thank you, Mike Copioli |
Mike, do you know what the availability of this chicklet will be? (will there be enough for at least one per team?)
thanks, /dan |
I really dont think the demand will be that high. We will see though.
#10
It would be pretty cool if they were included in the kit of parts, but that would be a rather expensive item to add. It might be worth it though, because then you could open up a whole new range of ways to control the robots.
#11
$130 x 1000. Yeah thats quite a bit of money. FIRST wants to get the most bang for the buck. I dont think theres a major issue with what is out there for controls now to need the extra cost. However, if FIRST would do this i doubt they would but from this company. Instead I would think IFI would design something and make it internal on the OI.
#12
The reason being is the current system is extremely easy wire, for teams that want custom controls. By going USB for OI controls, teams would have to either rip apart off the shelf controllers or program their own HID compliant chip. For 95% of the teams the current system works very well. Mike's device fills a need, it would be nice to see it streamlined into a nice case and pull power from the OI. I just hope this device convinces IFI to allow for externally powered control interfaces. So we can can use the Wii remote to drive the robot this year .Last edited by Kingofl337 : 01-01-2007 at 22:09. |
#13
Why would you think this? |
#14
Is it possible to run multiple joysticks through a USB hub using only one unit?
#15
The Chicklet only supports HID. It does not support HUB. We have a solution that does support HUB and other device classes however that solution was not cost effective. We wanted to keep the device affordable for FIRST Teams. Also the 15-pin joystick port does not provide enough interface to support more than one device. We have a device that outputs RS232 data instead of analog/digital. It is less expensive than the chicklet. If we had a serial port on the O/I this would have been the way to go. Mike Copioli CTRE team 217 |
| intelitek loader/vex USB-serial adapter driver | MrForbes | Programming | 2 | 07-04-2006 13:37 |
| USB serial adapter for OSX? | Validius | Programming | 1 | 05-01-2006 01:43 |
| USB-Serial adapter | Bill_Hancoc | Chit-Chat | 4 | 03-01-2006 07:18 |
| USB to Serial adapter | John Gutmann | Programming | 7 | 09-05-2005 01:34 |
| BAFO USB to 9 Pin Adapter | Skiguy523 | Programming | 2 | 29-01-2005 01:49 |
