Go to Post The whole idea of a robot competition is geared around spectators. Take that away and you have a science fair. - Chris is me [more]
Unread 23-12-2006, 15:08
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: pic: 6WD Module
Madison, we are quite impressed with the idea of removable six wheel modules, and have begun to think about the design of one.
My question is, how to you intend to attach the modules to your frame? I've considered welding angle onto the outside frame, angle onto the modules, bending tabs, etc., but I'm not completely pleased with these methods of attachment. We intend to use 1x1 tube, in the kitbot arrangment style- perhaps even the kitframe, and I run into problems intersecting gearboxes and motors with necessary frame members, just in my head.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 02-01-2007, 03:24
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: pic: 6WD Module
Madison,
As Andrew said, We have been developing a similar drive train, but are wondering how much each of your modules will weigh completed. As is, A completed frame with our currently designed module will weigh about 35-40 lbs, with each module weighing 15 -20 lbs. Is this comparable to yours?
Also, our current design differs from yours in that we will attach the modules directly together using aluminum tube, and that will form our primary Frame. Because of this, our modules had to be somewhat more... Robust, and are going to be made of a thicker plate, probably .20-.25 inch. As soon as we have some renderings we will post them, and thanks for your help in advance
-Cody C
Unread 02-01-2007, 04:03
Re: pic: 6WD Module
I think I'd go with more standoffs and thin plate rather than thick plate, but, as always, it all depends on a lot of things that aren't easy to predict and sometimes aren't easy to test for.
Unread 02-01-2007, 09:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 6WD Module
Madison,
-Cody C
That sounds pretty close to the weight calculated by Solidworks. My model is missing bolts, chain and little things like that and comes in at about 10 lbs. per module and 25 lbs. for the whole chassis.
I was planning on seating this design inside a frame of 3x1" aluminum channel, somehow using the spacers and bolts on each end in the scheme to attach it to the frame. I didn't develop it much further than that because I began in on yet another 6WD setup that's integrated wholly into the frame.
I'm looking forward to seeing your renderings. I'll likely be putting up some new renderings of the latest 6WD arrangement we've designed later today.
--Madison--
...down at the Ozdust!
Unread 02-01-2007, 14:10
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Re: pic: 6WD Module
Allrighty then, my renderings are up. (as soon as they are approved)
Unread 12-01-2007, 09:46
SleeveofWizard SleeveofWizard is offline
FRC #0066
SleeveofWizard is on a distinguished road
Re: pic: 6WD Module
What are the benefits of a 6WD over 4WD?
Unread 12-01-2007, 09:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: 6WD Module
You get more contact area between the drive wheels and the carpet when you use more wheels.
Some will argue that the reduced weight on each wheel makes it no more effective than a four-wheel system. Others will counter with the idea that the carpet fibers bend and thus have a maximum static friction force they will support for a given area.
Unread 12-01-2007, 10:09
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: pic: 6WD Module
With this 6 wheel setup with omni wheels in the corners you drag your wheels a lot less on the ground when you are turning in place. With 4 wheels you end up having more motion perpendicular to the wheel which, given a lot of traction in your wheels can really strain your drive train, and make turning much slower.
Unread 12-01-2007, 09:49
Re: pic: 6WD Module
I like the removable 6wd modules. Reminds me of something I will be seeing alot of this year.
Unread 12-01-2007, 09:52
Brandon Holley's Avatar
Re: pic: 6WD Module
hmm yes tom, it kinda does
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
6WD? Alex Cormier FIRST Tech Challenge 14 17-04-2006 22:10
pic: 494 Power Module KEY Extra Discussion 14 26-01-2005 17:50
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
