Go to Post That wiring job is so sexy I would date it. - RoboChair [more]
Unread 25-12-2006, 15:42
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: team 1881's trans V2
Depending on the size of the wheels you are planning on using, you may want to reduce the ratio further, but that can also be done after the gearbox (typically via chain and sprocket). But for a 5-6" that is probably around where you want.
2009 Trans-Am? Matt Attallah Chit-Chat 12 01-04-2006 01:08
Last years versus this years trans. ratios de_ Motors 4 12-01-2006 13:56
pic: Team 334 Team Members after the CeBit Convention CD47-Bot Extra Discussion 2 29-05-2004 14:14
Ohh Well another trans down the tube Matt Reiland Technical Discussion 20 15-01-2004 20:24
Has any one stuck a drill motor in the FP trans? Lotownvw Motors 15 21-04-2003 23:57
