Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Unread 27-12-2006, 23:54
pic: Drivetrain Side View
Unread 27-12-2006, 23:55
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is online now
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Re: pic: Drivetrain Side View
Looks like it is inspired from the 254/60/22 drive train.
Why couldn't the wheel be only two pieces by incorperating the hub into the wheel itself?
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 27-12-2006, 23:58
Engineering Mentor
FRC #0254
I love the button head screw to tension the chain. Nice touch.
-Travis Covington
Unread 28-12-2006, 00:41
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Just a few thoughts as 229 had a drive similar to this for triple play. Are you using a solid chain linking all the wheels together. We decided that we should use 2 chains one mid wheel to front wheel and one mid wheel to back wheel. in case one breaks you still have 2 wheels driving. Also if you use this in a game try to keep the robot balanced front to back otherwise you ed up with massive tread wear. But other than that great design, good luck in '07'
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 28-12-2006, 01:33
I modeled the drive train off of ideas behind of 254's drive train, and 968's tensioner.
Why couldn't the wheel be only two pieces by incorporating the hub into the wheel itself?
I designed the wheel so that it could be swapped out easily. All we have to do is to remove the six bolts, and the wheel is free to be swapped out. Also, one of our sponsors is a sheet metal manufacturer. They can easily cut out the 5 pieces of sheet metal that make up the wheel. The wheel has an 1/8 th inch thick rim, a 1/4 inch thick spoked section, two 1/4 inch body sections, and another 1/8 th thick rim. They would then spot weld these together in that order to make the wheel. By incorporating the hub into the wheel, we would have to start with a larger block of aluminum and wouldn't be able to make the wheel out of sheet metal.
I am doing the same thing. You can see the two sprockets on the main drive shaft in the other picture that I posted. Thanks for the advice on tread wear
Here is a render of our tensioning device. Once again, it is made out of sheet metal.
Unread 28-12-2006, 02:39
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Are the wheels being held on the shaft only by the clips, or is there something I'm missing?
Unread 28-12-2006, 03:19
It looks like snaprings. Those do a great job, I know 968 (and 254 as well?) used them this year. We also had all six of our wheels held on with snaprings and never popped one.
Unread 28-12-2006, 03:20
Rafi Ahmed's Avatar
Mentor & Alumni
It seems like it. The clips would be enough to keep on the wheels. 254, 60, 22, 968, 980, and 4 (thats all i can remember) used only clips and they work just fine
Team 2522 | Mentor
Unread 28-12-2006, 03:27
Nuttyman54's Avatar
Mentor, Tactician
well then, I'm convinced. I've never used them, so I wasn't sure how strong they were.
Unread 28-12-2006, 13:02
Yes, those are snap rings. Good call.
Unread 28-12-2006, 13:34
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Can you show a more detailed look at how the tensioner interfaces with the frame? I'm not clear on how it's supported.
I've been working on a similar design that requires as little complex machining as possible, as I'm the person who does all the CNC work on the team and there're few things I dislike more than sitting in front of the machine. The tensioning mechanism is one of the few details remaining, so it's interesting to see how others have decided to implement that detail.
--Madison--
...down at the Ozdust!
Unread 28-12-2006, 15:17
Here is a picture of how the part that I posted earlier fits into the frame. I moved one of the side plates out of the way so that you can see how the part fits in the frame.
Unread 28-12-2006, 17:27
Madison's Avatar
FRC #0488 (Xbot)
Thanks for clearing that up. Are you relying on the tension of the chain to prevent the buttonhead screw and tensioning mechanism from moving outward (left in the picture)?
Also, I like the display style a lot.
--Madison--
Unread 28-12-2006, 17:37
Correct, I am relying on the tension of the chain to prevent the buttonhead screw from moving outward.
Unread 28-12-2006, 22:30
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
that my friend is beautiful...i wish i had the patience to design something like that. Very nicely done.
MechWarriors 573
pic: Team 226 side view CD47-Bot Robot Showcase 8 25-02-2004 16:25
pic: Team 271's Side View CD47-Bot Robot Showcase 1 17-03-2003 18:48
pic: A Side View of Team 898's robot CD47-Bot Robot Showcase 2 07-03-2003 03:05
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
pic: 141's Robot stacking side view CD47-Bot Robot Showcase 7 28-02-2003 12:16
