Go to Post Rules are after all rules. They don't have to make sense. - ChrisH [more]
Unread 27-12-2006, 22:34
Re: pic: 2 Speed Transmission
While all of the points you guys bring up are valid, and great things to keep in mind when choosing gear ratios during the season, I just chose those two speeds because those were speeds that I thought might be useful for a game like last year.
When the new season starts, I am going to re-evaluate the gear ratios, and redesign that part of the transmission. I see no point in speculating about the next season and choosing a specific gear ratio before the challenge is released. I just started with 2 gear ratios so that I would have a basic design to build off of and adjust to the challenge when the season starts. Most likely, I will keep the 5 ft/sec, and adjust the top speed to a speed that fits the challenge better.
Thanks for all of the great input on my design.
What dimensions do teams normally use for the size of their dog, and the depth that the teeth of the dog go into the gears? I am currently using 1/2 inch hex, and the dog's teeth are 7/16 of an inch long.
Unread 28-12-2006, 10:03
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I use a square dog with an outside shift plate. 'Teeth' are .160" long and engagement in the gear is .140". You can see this is the white papers in our 2005 gearbox.
This design has had no problems in two years of competition. The only thing about building your own is you have to build, and break in, new gearboxes every year.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 28-12-2006, 14:26
I am having trouble putting this next sentence in plain english, so bare with me.
When the dog's teeth just leave the face of one of the two gears with holes cut in them to accept the dog's teeth, how much clearance should I have between the dog's other set of teeth and the other gear?
I think last year I did something like .020 neutral space. I mean, if it clears, it clears; no need to clear by a big amount. Just make sure that under no circumstances are both gears angaged at once.
Our shifting dogs went something like .13" into the gears and were something like 1" OD.
Unread 28-12-2006, 17:04
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H²O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
Yea, we found out after getting the kit tranny's that it was alot more efficient to use them. Instead of spending 2 - 3 weeks designing and machining tanny's, we can use that extra time to design and perfect another aspect of the machine. Remember it's not always about speed and strength(but even if it was, the kit tranny's provide enough speed and torque), but how efficient you are at doing a certain task as well.
But kudos to all the teams who design bot kicking tranny's! haha
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Unread 29-12-2006, 00:52
If anyone is interested, here are the Solidworks files for the transmission and drivetrain. If you end up using any part of them durring the season, I would love to know about it. Please let me know if there is a problem with the files, or something doesn't make sense.
http://www.boardsailor.com/austin/CDExport12-28.zip
Unread 30-12-2006, 16:39
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Remember that while engineering something it is often much easier to try to adapt existing products to fit your design instead of having to create everything from scratch. On that note look into buying your dogs and Dogged gears from a company with experience making them right(such as AndyMark) itll make your life so much easier to just buy the dog compatible pieces from them and play around with your gear reductions to make it fit your design.
-Simon
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 05-09-2006 19:03
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 22-05-2006 13:35
pic: 2 Speed Vex Transmission cire FIRST Tech Challenge 12 20-05-2006 21:14
pic: S.P.A.M "Littles-C" 12 speed transmission EricS-Team180 Extra Discussion 31 27-01-2005 21:20
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
