Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 30-12-2006, 11:37
MAteo9944's Avatar
MAteo9944 MAteo9944 is offline
Knowledge Sponge
AKA: Matt Carroll
FRC #1379 (Gear Devils)
MAteo9944 will become famous soon enough
Send a message via AIM to MAteo9944
Re: pic: Shaft Drive Bearing Blocks
Originally Posted by Ben Piecuch View Post
It looks like you are machining your own wheels. If that's the case, why don't you just make a center wheel that is slightly bigger that the two outer ones. The speed of that wheel will be negligibly higher than the outer two, but it will allow you to have a standard pillow block in there, as opposed to the IGUS ones. This could make for a possibly more robust drive setup, as some teams had problems with those plastic IGUS bearings last year.
BEN
This is actually something that I considered for a while, but one of my team's ME mentors talked me out of it. I can't figure out if it would be a problem or not. I probably need to test it out and see. If anyone has experience with this could you please help me out?
As for the IGUS bearings, they should be fine. They are not under too much load from the miter gears. We are using conventional ball bearings where there are higher loads.
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
