Re: pic: DeWalt Gearbox with two CIMs
From my experience in drive train design I will always advise that people go with a central gearbox and power transmitted through chain or another means. This is due to your overall friction force (another discussion) but basically if you spread out the load to all of your wheels each wheel can take the total torque produced in the situation where another set is off the ground (assuming the mass is over the wheels touching the ground) that is where the normal force/ weight of the robot plays in (yet another discussion) either way keeping your motors together will save you weight in the long run and give you the nice ability to put the torque everywhere you want it to be in the correct situations. |
But then again, maybe it is because it is 2:30 in the morning. |
Torque from dc motors is theoretically limitless, the more voltage you put to the motor the higher the torque you can create. Now in a real world (FIRST included) motors can only take so much voltage before they burn up. So especially in FIRST where your voltage is limited so is your maximum torque. The best way that I can think of describing the scenario in question is by comparing it to water. If the gearbox is designed correctly to maximize torque without drawing more then 40 amps then you have 1 full water container. This container got it's water (torque) from both motors combined (the max before tripping breakers). Separating the motors is like pouring the water into 2 glasses, you still have the same amount of water it is just in a different place. Because torque is limited by voltage and amperage it doesn't matter how you split it, it will remain the same. Assuming the same gear ratio in each gearbox consider the following max torque out of 1 transmission with 4 motors = combined max torque of 2 transmissions with 2 motors each = combined max torque of 4 transmissions with 1 motor each. Now there are other things to consider like gearbox inefficiencies and other losses but for all intensive purposes you can pass the water around all day but in the end you are still left with the same amount of water. |
Another thing that you hinted at was that if you have 4 transmissions, if some of your wheels lose grip or leave the ground then you suddenly have less torque available. (If your wheels are leaving the ground during a pushing match you have other problems.)
True but I was thinking more like climbing a ramp, once your weight leaves the front wheels the weight transfers to your back wheels. If you are running a gearbox with all wheels connected your effective force is the same because your normal force and traction is constant. If you run 1 motor to each wheel (not connected) then your effective force is much less due to the loss of normal force over your front wheels. depending on the situation it could be as much as half the total power of the system.
| pic: Version 2 of the 2 CIM into 1 DeWalt gearbox | MAteo9944 | Extra Discussion | 3 | 21-01-2007 13:00 |
| Using two CIMs in the Banebots Transmission | Justin M. | Technical Discussion | 15 | 09-01-2007 09:41 |
| Flexible shafts working with CIMs | mechanicalbrain | Motors | 8 | 07-07-2006 23:38 |
| pic: GEAR BOX with two speed | ericwittlich | Extra Discussion | 6 | 19-07-2005 22:01 |
| how to wire the new two motor gearbox | Vince lau | Electrical | 10 | 14-02-2005 07:30 |
