Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Unread 31-12-2006, 02:37
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: DeWalt Gearbox with two CIMs
Originally Posted by Cody C View Post
I'm confused... I don't quite see where this paragraph fits in with proving that there will never be more torque if you put the motors through separate gearboxes. Maybe it's just me only having a highschool physics background, but are some of the words taken a bit out of context? maybe a diagram would help me? I understand the terminology, this paragraph just confuses me.
But then again, maybe it is because it is 2:30 in the morning.
not a problem, I am only half awake myself. That paragraph is talking more about the design system then proving that there won't be more torque. But since you asked I will explain why you don't get more torque.
Torque from dc motors is theoretically limitless, the more voltage you put to the motor the higher the torque you can create. Now in a real world (FIRST included) motors can only take so much voltage before they burn up. So especially in FIRST where your voltage is limited so is your maximum torque. The best way that I can think of describing the scenario in question is by comparing it to water. If the gearbox is designed correctly to maximize torque without drawing more then 40 amps then you have 1 full water container. This container got it's water (torque) from both motors combined (the max before tripping breakers). Separating the motors is like pouring the water into 2 glasses, you still have the same amount of water it is just in a different place. Because torque is limited by voltage and amperage it doesn't matter how you split it, it will remain the same.
Assuming the same gear ratio in each gearbox consider the following
max torque out of 1 transmission with 4 motors
combined max torque of 2 transmissions with 2 motors each
combined max torque of 4 transmissions with 1 motor each.
Now there are other things to consider like gearbox inefficiencies and other losses but for all intensive purposes you can pass the water around all day but in the end you are still left with the same amount of water.
Greg Needel│www.robogreg.com
Unread 31-12-2006, 02:43
MAteo9944's Avatar
MAteo9944 MAteo9944 is offline
Knowledge Sponge
AKA: Matt Carroll
FRC #1379 (Gear Devils)
MAteo9944 will become famous soon enough
Send a message via AIM to MAteo9944
Another thing that you hinted at was that if you have 4 transmissions, if some of your wheels lose grip or leave the ground then you suddenly have less torque available. (If your wheels are leaving the ground during a pushing match you have other problems.)
Unread 31-12-2006, 02:47
True but I was thinking more like climbing a ramp, once your weight leaves the front wheels the weight transfers to your back wheels. If you are running a gearbox with all wheels connected your effective force is the same because your normal force and traction is constant. If you run 1 motor to each wheel (not connected) then your effective force is much less due to the loss of normal force over your front wheels. depending on the situation it could be as much as half the total power of the system.
pic: Version 2 of the 2 CIM into 1 DeWalt gearbox MAteo9944 Extra Discussion 3 21-01-2007 13:00
Using two CIMs in the Banebots Transmission Justin M. Technical Discussion 15 09-01-2007 09:41
Flexible shafts working with CIMs mechanicalbrain Motors 8 07-07-2006 23:38
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
