Re: pic: DeWalt Gearbox with two CIMs
Another thing that you hinted at was that if you have 4 transmissions, if some of your wheels lose grip or leave the ground then you suddenly have less torque available. (If your wheels are leaving the ground during a pushing match you have other problems.)
True but I was thinking more like climbing a ramp, once your weight leaves the front wheels the weight transfers to your back wheels. If you are running a gearbox with all wheels connected your effective force is the same because your normal force and traction is constant. If you run 1 motor to each wheel (not connected) then your effective force is much less due to the loss of normal force over your front wheels. depending on the situation it could be as much as half the total power of the system.
| pic: Version 2 of the 2 CIM into 1 DeWalt gearbox | MAteo9944 | Extra Discussion | 3 | 21-01-2007 13:00 |
| Using two CIMs in the Banebots Transmission | Justin M. | Technical Discussion | 15 | 09-01-2007 09:41 |
| Flexible shafts working with CIMs | mechanicalbrain | Motors | 8 | 07-07-2006 23:38 |
| pic: GEAR BOX with two speed | ericwittlich | Extra Discussion | 6 | 19-07-2005 22:01 |
| how to wire the new two motor gearbox | Vince lau | Electrical | 10 | 14-02-2005 07:30 |
