Re: pic: Shaft Drive Bearing Blocks
Matt,
I know that the drawing may not show the components in correct scale but with this kind of drive there are some significant forces that need to be addressed. The rotational forces on each shaft when pushing or in stall will produce a side force if you think about it. Because of those forces, larger bearings and stiffer blocks are needed relative to other types of drive. Without the extra beef, misalignment and high frictional forces will occur in the bearings and shafts. Think of the construction of a car differential and you will get an idea of the kind of strength you will need. |
There's been alot of good engineering concerns (side forces, stress on the shaft, etc...)
Here's one more. Imagine hitting it with a sledge hammer. Can you get it working again in 5 minutes? Can you get a chain drive working again in 5 minutes? |
| Extending a cantilevered drive shaft. | Madison | Technical Discussion | 18 | 04-11-2005 00:27 |
| Drive-train shaft size | Andrew Schuetze | Technical Discussion | 27 | 27-07-2005 15:41 |
| pic: Linear bearing + mount | Alex1072 | Robot Showcase | 6 | 02-02-2005 11:13 |
| drill motor drive shaft attachment | archiver | 2001 | 1 | 23-06-2002 22:32 |
| shaft drive | Joseph F | Technical Discussion | 5 | 03-02-2002 17:51 |
