Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 31-12-2006, 22:27
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: pic: Shaft Drive Bearing Blocks
Originally Posted by MAteo9944 View Post
The problem with worm gears is in the efficiency. They are usually about 60-70% efficient as opposed to the 95% efficiency of a miter gear. Some worm gears are even as low as 20% though I have also seen 98% reported.
Depending on the game and strategy, the resistance of worm gears to being back driven may be advantageous, or a significant disadvantage. However, I think it would take a lot of strategy advantage to make up for the loss in efficiency.
And it would make it about impossible to push the robot around without turning it on and having the controls. Since it usually has to go in the back of my truck to go to demos, etc. I would really hate that
Unread 01-01-2007, 11:22
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
I was not sure of the efficiency of a worm gear system. I did not analyze how a worm gear system would be disadvantageous to a team and only looked at the advantages. I saw that the robot would be very responsive (Like when the driver would let go of the joysticks, it would immediately stop) and that other robots could not push my team's robot around, but then you said that it would be a "significant disadvantage," which I can see happening very easily. It would be almost impossible to push a locked robot across the field in the time frame that FIRST gives us during a match. Another disadvantage I found, and I'm not sure if you guys said or not, is that when pushing a robot, the efficiency of the system decreases as friction between the gears increases... I remember this now from my Erector Set when I was a kid. Brings back some memories... Now back to reality; now that I see the disadvantages, I would not use a worm gear system. I guess another advantage that I thought of is that this system would probably be more reliable than our traditional chain method.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
