Go to Post we came together, worked our butts off, and eventually looked at failure and decided....its just not our style. - Monochron [more]
Unread 12-31-2006, 06:48 PM
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
pic: Planetary wheel (cutaway)
Unread 12-31-2006, 06:51 PM
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Planetary wheel (cutaway)
2007 will be a year of robot design innovation.
Go ahead and make a wheel hub that goes right over the bearings and retained with ring clips on each shaft. This way you can remove the planetary gearing if something goes wrong and still use the wheel, or vice versa.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 12-31-2006, 06:53 PM
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by 11Ed71 View Post
Cutaway view of an idea I had that I fleshed out into a design. It will probably never get built, but here's the first revision of the design. All parts are stock parts available from McMaster or SDPSI or are easily machinable on a CNC mill. Opinions are welcome, but if all you're going to say is that it won't work, I don't need to hear that.
Side loads may be an issue, but since the whole thing is riding on roller bearings, I don't think it will be.
Completed, the module runs directly off a CIM, and is bolted to a frame member on both sides (this mounting plate isn't visible here to make the gearing visible), with the wheel part (everything seen here) spinning at a 16:128 reduction. (Stationary planets, driven ring as output/wheel surface.) The wheel surface would be sheet metal with some kind of rubber tread.
How are you supporting the outer ring with respect to the planet gears and planet carrier? If your outer ring can wobble about the central axis, you're probably going to encounter a lot of uneven tooth wear. You definitely can't rely upon the tooth mesh to support the weight of the robot.
Also, is the 16 tooth gear hardened steel? Because it probably ought to be. (What's the SDP/SI part number?)
Unread 12-31-2006, 07:26 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Out of curiosity, where does the planet carrier come from?
--Madison--
...down at the Ozdust!
Unread 01-01-2007, 01:44 PM
Back in the Game
AKA: Ed Venator
FRC #2399
Materials aren't final, but I believe it was hardened steel.
As for the ring, you'll see there is a ring gear and a circular aluminum ring (2 actually, but only one visible), which is bolted to the ring gear. The aluminum rings are riding on bearings on the planet shafts(those 3 cylinders), which take all of the load of the weight of the robot.
Everything but the gears and bearings would be custom-machined.
Again, odds are this will never be built, I just wanted to see the public reaction. Even if this design does see the light of day, it won't be on MORT '07. (Not my department, I'm end effectors.)
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 01-01-2007, 02:45 PM
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Thats crazy ed, post a picture of the whole assembly with the mounting plate.
How much do you estimate it weighs?
looks intense
Unread 01-01-2007, 02:56 PM
Back in the Game
AKA: Ed Venator
FRC #2399
I posted a new picture here.
Inventor says the weight is around 1.9 pounds (plus CIM and mounting hardware.) I don't trust that number because I haven't double-checked my materials and because it's an inherently rough estimate, but I expect the final to weight in under three pounds, which compares pretty well to the kit gearbox if I remember correctly.
MORT 11
HB 2399
Designing a Planetary Wheel (Almost) lndnny General Forum 14 10-25-2005 03:27 PM
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 06-27-2005 04:05 PM
pic: Planetary Wheel - Exploded View 4 Matt Krass Extra Discussion 5 06-23-2005 11:56 PM
pic: 222 3 speed closeup/cutaway CD47-Bot Robot Showcase 64 04-25-2004 03:25 PM
pic: Planetary Gearset CD47-Bot Robot Showcase 3 12-22-2003 01:55 AM
