Re: pic: 6WD Module
Allrighty then, my renderings are up. (as soon as they are approved)
Re: pic: 6WD Module
What are the benefits of a 6WD over 4WD?
Re: pic: 6WD Module
You get more contact area between the drive wheels and the carpet when you use more wheels.
Some will argue that the reduced weight on each wheel makes it no more effective than a four-wheel system. Others will counter with the idea that the carpet fibers bend and thus have a maximum static friction force they will support for a given area. |
Re: pic: 6WD Module
With this 6 wheel setup with omni wheels in the corners you drag your wheels a lot less on the ground when you are turning in place. With 4 wheels you end up having more motion perpendicular to the wheel which, given a lot of traction in your wheels can really strain your drive train, and make turning much slower.
| pic: Completed Mecanum Module | Madison | Technical Discussion | 9 | 12-11-2006 19:39 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
| 6WD? | Alex Cormier | FIRST Tech Challenge | 14 | 17-04-2006 22:10 |
| pic: 494 Power Module | KEY | Extra Discussion | 14 | 26-01-2005 17:50 |
| pic: Tytus's Coax Crab Module | CD47-Bot | Robot Showcase | 8 | 17-11-2003 10:08 |
