Re: pic: FRC488 - Six Wheel Drive Chassis
A couple of questions:
Does that have any rocker in it? And is that 25 or 35 chain? |
Why omniwheels on a 6WD?
Turning, I'd say. Instead of lowering the center wheel, why not use omni's? It's more stable and more maneuverable. (It's also easier to spin around by hitting.)
Not necessarily more maneuverable, But I bet it is nice to have the 'bot spin around it's center set of wheels instead of whichever four happen to be touching the ground
Wow, looks light! Do you have an estimated weight for the entire drive base?
And on the subject of omniwheels: It looks like with the setup you have it would be very easy to swap them for traction wheels if they are needed. I guess that would be decided in testing. |
Can you explain why you chose not to have a cross brace? I'm not a mech-e but I would guess you need one.
Because the center wheel is not lowered at all, at least one outside set of wheels should be omniwheels to alleviate friction while turning. I chose to put a set on each end because there's no penalty to in line pushing force, generally, and I like to subtley encourage our drivers to avoid conflict. ![]() Quote:
The omniwheels are riding on 5/8" keyed shaft, while the AndyMark performance wheel is broached for a 1/2" hex shaft. It'd be relatively easy to change out a set of omniwheels for a set of traction wheels with a little bit of forethought. Namely, I'd need to make some shafts that are 5/8" diameter with keyway on one end and 1/2" hex on the other. I'm waiting on the game before adding cross-bracing since I'm not sure if I'll need a scoop or something on one or both ends. I'd like to, if weight allows, put an aluminum plate (1/16" or so) across the bottom to add rigidity. |
I noticed that the front and rear c channels are notched for the drive rails on top and bottom. This could be a weak point. Shouldn't the drive rails fit inside the c channel leaving the channel uncut ?
#10
M -
Looks quite nice, and you have obviously put a lot of work and thought into the design. The efforts to minimize the total weight are obvious. The biggest concern you may have is strength in the event of an impact or collision. You might consider making the frame members out of rectangular tube instead of channel. Given the amount of material you are removing, the additional weight from the fourth side of the tube will be minimal, but there will a considerable increase in stiffness of the frame assembly. Just out of curiosity, what is the spacing between the wheel sets? Is it sufficient to cross a 20-inch wide, 16-inch deep, water-filled moat, should that capability ever be necessary? -dave Last edited by dlavery : 03-01-2007 at 00:03. |
#11
Oh goodness.
#12
Here we go again...
#13
Any crocs? CRIKEY! |
#15
WATCH OUT!!! WE'VE GOT A DAVE ON THE LOOSE!!! SOS...SOS...SOS
| pic: 4 Wheel Strafing Chassis | Holtzman | Extra Discussion | 9 | 08-07-2009 19:28 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| pic: Omni Wheel Drive -- Top | Richard Wallace | Extra Discussion | 4 | 05-12-2005 18:55 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: 6 wheel drive train pick | CD47-Bot | Robot Showcase | 3 | 14-04-2004 07:10 |
