Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 02-01-2007, 22:30
EricH EricH is offline
Re: pic: FRC488 - Six Wheel Drive Chassis
Originally Posted by Joel J. View Post
Why omniwheels on a 6WD?
Turning, I'd say. Instead of lowering the center wheel, why not use omni's? It's more stable and more maneuverable. (It's also easier to spin around by hitting.)
Unread 02-01-2007, 22:32
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Not necessarily more maneuverable, But I bet it is nice to have the 'bot spin around it's center set of wheels instead of whichever four happen to be touching the ground
Unread 02-01-2007, 22:38
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Wow, looks light! Do you have an estimated weight for the entire drive base?
And on the subject of omniwheels: It looks like with the setup you have it would be very easy to swap them for traction wheels if they are needed. I guess that would be decided in testing.
Unread 02-01-2007, 23:07
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Can you explain why you chose not to have a cross brace? I'm not a mech-e but I would guess you need one.
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 02-01-2007, 23:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by dhoizner View Post
A couple of questions:
Does that have any rocker in it? And is that 25 or 35 chain?
The wheels are all in line -- there's no 'rock' at all. The chain is #25.
Because the center wheel is not lowered at all, at least one outside set of wheels should be omniwheels to alleviate friction while turning. I chose to put a set on each end because there's no penalty to in line pushing force, generally, and I like to subtley encourage our drivers to avoid conflict.
Originally Posted by Gdeaver View Post
If the bumpers are back and the design is like 2006, then the next step is to add mounting to this frame that would allow the bumpers to be a structural element. If the rules allow forget home center plywood. Baltic birch "wood" be a good choice.
I'm now looking at a mounting scheme that will accept bumpers and protect the wheels from impact. I've never put bumpers on a robot before, so I'm looking at examples of others' work to get an idea how to best accomodate the additional weight of the bumper assembly.
Our 2005 robot had a lowered center wheel and the tipping action drove me and our drivers crazy. It's an impact to the system each time the robot's inertia shifts and that starts to lead to annoying things like loosened bolts and the like. Practically, it's cheaper and easier for me to make omniwheels than it is to make traction wheels and it's certainly cheaper than buying them.
As shown -- which includes everything but stiffening gussets and a base upon which to mount electronics, it's 29.5 lbs.
The omniwheels are riding on 5/8" keyed shaft, while the AndyMark performance wheel is broached for a 1/2" hex shaft. It'd be relatively easy to change out a set of omniwheels for a set of traction wheels with a little bit of forethought. Namely, I'd need to make some shafts that are 5/8" diameter with keyway on one end and 1/2" hex on the other.
I'm waiting on the game before adding cross-bracing since I'm not sure if I'll need a scoop or something on one or both ends. I'd like to, if weight allows, put an aluminum plate (1/16" or so) across the bottom to add rigidity.
--Madison--
...down at the Ozdust!
Unread 21-01-2007, 21:41
foundbobby foundbobby is offline
Team President
AKA: Robert Fischer
FRC #0670 (Homestead Robotics)
foundbobby will become famous soon enough
Nice design. What about having the wheels on the outside? Don't they need be protected some to avoid bent shafts and broken wheels?
Unread 02-01-2007, 23:33
Gdeaver Gdeaver is offline
FRC #1640
I noticed that the front and rear c channels are notched for the drive rails on top and bottom. This could be a weak point. Shouldn't the drive rails fit inside the c channel leaving the channel uncut ?
Unread 03-01-2007, 00:00
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
M -
Looks quite nice, and you have obviously put a lot of work and thought into the design. The efforts to minimize the total weight are obvious. The biggest concern you may have is strength in the event of an impact or collision. You might consider making the frame members out of rectangular tube instead of channel. Given the amount of material you are removing, the additional weight from the fourth side of the tube will be minimal, but there will a considerable increase in stiffness of the frame assembly.
Just out of curiosity, what is the spacing between the wheel sets? Is it sufficient to cross a 20-inch wide, 16-inch deep, water-filled moat, should that capability ever be necessary?
-dave
Unread 03-01-2007, 00:02
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Oh goodness.
Unread 03-01-2007, 00:15
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Here we go again...
Unread 03-01-2007, 00:17
Madison's Avatar
FRC #0488 (Xbot)
-dave
--Madison--
Unread 03-01-2007, 00:22
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
-dave
Any crocs?
CRIKEY!
Unread 03-01-2007, 07:51
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
WATCH OUT!!! WE'VE GOT A DAVE ON THE LOOSE!!! SOS...SOS...SOS
Unread 05-01-2007, 12:28
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
That looks very nice and pretty well engineered. My suggestions are that you only use one set of omni wheels. You have to admit that you will be getting in to conflict no matter what you do.
The frame does look pretty sound, but with all that material taken out, are you worried about bending at all? these bots go through some pretty hard hits.
But i am very impressed by your design and i look forward to seeing the end product after the next hectic 6 weeks =)
--Dan
Unread 03-01-2007, 09:23
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
M -
-dave
Who keeps letting him in? Security!!!
I love the simple approach to the 6-wheel drive. I'll be follwing up later if you use this to see what additional stiffening was used/needed. Good luck.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
pic: 4 Wheel Strafing Chassis Holtzman Extra Discussion 9 08-07-2009 19:28
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
