Originally Posted by dhoizner
A couple of questions:
Does that have any rocker in it? And is that 25 or 35 chain?
The wheels are all in line -- there's no 'rock' at all. The chain is #25.
Originally Posted by Joel J.
Why omniwheels on a 6WD?
Because the center wheel is not lowered at all, at least one outside set of wheels should be omniwheels to alleviate friction while turning. I chose to put a set on each end because there's no penalty to in line pushing force, generally, and I like to subtley encourage our drivers to avoid conflict.
Originally Posted by Gdeaver
If the bumpers are back and the design is like 2006, then the next step is to add mounting to this frame that would allow the bumpers to be a structural element. If the rules allow forget home center plywood. Baltic birch "wood" be a good choice.
I'm now looking at a mounting scheme that will accept bumpers and protect the wheels from impact. I've never put bumpers on a robot before, so I'm looking at examples of others' work to get an idea how to best accomodate the additional weight of the bumper assembly.
Originally Posted by Cody C
Not necessarily more maneuverable, But I bet it is nice to have the 'bot spin around it's center set of wheels instead of whichever four happen to be touching the ground
Our 2005 robot had a lowered center wheel and the tipping action drove me and our drivers crazy. It's an impact to the system each time the robot's inertia shifts and that starts to lead to annoying things like loosened bolts and the like. Practically, it's cheaper and easier for me to make omniwheels than it is to make traction wheels and it's certainly cheaper than buying them.
Originally Posted by s_forbes
Wow, looks light! Do you have an estimated weight for the entire drive base?
And on the subject of omniwheels: It looks like with the setup you have it would be very easy to swap them for traction wheels if they are needed. I guess that would be decided in testing.
As shown -- which includes everything but stiffening gussets and a base upon which to mount electronics, it's 29.5 lbs.
The omniwheels are riding on 5/8" keyed shaft, while the AndyMark performance wheel is broached for a 1/2" hex shaft. It'd be relatively easy to change out a set of omniwheels for a set of traction wheels with a little bit of forethought. Namely, I'd need to make some shafts that are 5/8" diameter with keyway on one end and 1/2" hex on the other.
Originally Posted by MikeDubreuil
Can you explain why you chose not to have a cross brace? I'm not a mech-e but I would guess you need one.
I'm waiting on the game before adding cross-bracing since I'm not sure if I'll need a scoop or something on one or both ends. I'd like to, if weight allows, put an aluminum plate (1/16" or so) across the bottom to add rigidity.
