Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Unread 03-01-2007, 18:37
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: paper: Modular Sub-Processing
Originally Posted by ericand View Post
The setup described in the paper is interesting, but seems to violate custom circuit rule R59 (2006 rules) which says that custom circuits may not "Directly affect any output devices on the robot, such as ... supplying a PWM signal to a speed controller..."
We had a custom circuit (PIC) to monitor the rotational speeds of the ball shooter motors, but the hard part was figuring out a communication mechanism back to the RC so that it could make the PWM changes if the speed was too slow or too fast. If we could have had the PIC control the speed directly, we would have had much better control. As it was, the RC just got 2 bits for each motor, which it interpreted as {too fast, just right, too slow, unused state). The RC then adjusted the motor controlling PWM directly (thus in compliance with R59), based on the input from the custom circuit.
Thanks for bringing this up. That's a bit embarrassing...I should have read through the custom circuitry rules a bit more carefully, but I got caught up in what seemed like a cool idea. I have added a disclaimer to the paper description and will look into other ways to do it, although I would agree that it becomes a much harder challenge and much of the benefit is lost. It was still an interesting as a side-project, though.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Critique my image processing program... Salik Syed Programming 13 29-06-2006 16:57
Outsourcing Processing/Storage Mike Chit-Chat 0 26-06-2005 21:06
Processing pre-set Interrupts Tom Bottiglieri Programming 1 13-02-2005 15:41
Processing data quickly in autonomous jgannon Programming 4 04-01-2005 14:45
Parallel processing for 3dmax mnkysp6353 General Forum 9 06-05-2004 10:26
