#16
Re: pic: FRC488 - Six Wheel Drive Chassis
WATCH OUT!!! WE'VE GOT A DAVE ON THE LOOSE!!! SOS...SOS...SOS
#17
I love the simple approach to the 6-wheel drive. I'll be follwing up later if you use this to see what additional stiffening was used/needed. Good luck. |
#18
Because of the holidays primarly, we haven't really done much of anything with our mecanum drive prototype. It still has no feedback system installed and remains difficult to drive. Most of the team agrees that, unless it appears to be a perfect solution for the new game, we'll stick with something more traditional like this drive, so there's a good chance you'll be seeing it somewhere. |
#19
Madison, I know that you have no broach capability, so I'm curious- where do you buy your #25 sprockets? I can't find any finished ones online, or in the Browning catalog.
#20
Wouldn't the spinning of the robot automatically lift the front and back wheels up and equal distance from the floor? Kind of like when your arms raise up when you spin around.
#21
Maybe on a perfectly 4-way symmetrical robot, but in My team's experience, It stays on 4 wheels and rocks back and forth... Whichever four wheels happen to be touching are the ones the bot spins around. Kinda messes up high-speed maneuvering.
#22
For this, we'll be ordering from McMaster-Carr -- part no. 2737T123. 5/8" bore was the smallest I found with a keyway for this particular sprocket. I didn't take a comprehensive look at many teeth counts, though, so I'm not sure how consistent the keyways are in 5/8" bore sprockets -- but I can't imagine why they all don't have one.
#23
Ah, I see. We were going to be using 1/2" bore, and for some reason, no one on earth carries broached 1/2" bore sprockets. Thanks though!
#24
The last two years I worked on center-drive, 6-wheel robots and both times we purposely loaded one end of the 'bot with a LOT more weight for game reasons. This also had the effect of having the same four wheels on the ground most of the time. We had little fore-and-aft rocking and the robot wasn't tricky to steer at all. Having said that, Madison makes nice chassises -- er, chasses -- er, chassisses -- what IS the plural of chassis anyway? I'd hire her to consult on our chassis, but since I'm now on a VEX-only team, I think we'd be wasting her skills.
#25
That looks very nice and pretty well engineered. My suggestions are that you only use one set of omni wheels. You have to admit that you will be getting in to conflict no matter what you do.
The frame does look pretty sound, but with all that material taken out, are you worried about bending at all? these bots go through some pretty hard hits. But i am very impressed by your design and i look forward to seeing the end product after the next hectic 6 weeks =) --Dan |
#27
team 1783, which is my schools team, used a different drivetrain set up, we had designed a setup where each side had indepent suspension, and two wheels for each side. and this year (depending on the game) i have designed a three speed gear box that would be incorperated into our original design. also i was thinking about trying out a four whee drive design that would be built by me and a local shop. how many of you guys know about the xmods remote control cars at radio shack? well i got one for christmas (god only knows why) but i was looking at upgrades for it and i saw that they have a four wheel drive kit for them. and after hours of configuring, and designing i think that i can build the 4 wheel drive suspension and drivetrain for our robot.
#28
Stop by if you feel you are missing out on the hectic 6 weeks that is FRC this season! |
#29
chassis, singular = chassis, plural
the plural would have a wee different pronunciation though |
#30
One chass-ee, two chass-ease.
| pic: 4 Wheel Strafing Chassis | Holtzman | Extra Discussion | 9 | 08-07-2009 19:28 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| pic: Omni Wheel Drive -- Top | Richard Wallace | Extra Discussion | 4 | 05-12-2005 18:55 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: 6 wheel drive train pick | CD47-Bot | Robot Showcase | 3 | 14-04-2004 07:10 |
