Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 05-01-2007, 12:25
CE Mexican CE Mexican is offline
FRC #1783
CE Mexican is an unknown quantity at this point
Re: pic: FRC488 - Six Wheel Drive Chassis
Originally Posted by dlavery View Post
M -
Looks quite nice, and you have obviously put a lot of work and thought into the design. The efforts to minimize the total weight are obvious. The biggest concern you may have is strength in the event of an impact or collision. You might consider making the frame members out of rectangular tube instead of channel. Given the amount of material you are removing, the additional weight from the fourth side of the tube will be minimal, but there will a considerable increase in stiffness of the frame assembly.
Just out of curiosity, what is the spacing between the wheel sets? Is it sufficient to cross a 20-inch wide, 16-inch deep, water-filled moat, should that capability ever be necessary?
-dave
I agree wiht what dave said about strenght, but on the contrary our team used aluminum channel for our frame and we didnt seem to have and problem with strength, and our frame took quite a beating during aim high this year
Unread 05-01-2007, 12:36
FRC #1783
team 1783, which is my schools team, used a different drivetrain set up, we had designed a setup where each side had indepent suspension, and two wheels for each side. and this year (depending on the game) i have designed a three speed gear box that would be incorperated into our original design. also i was thinking about trying out a four whee drive design that would be built by me and a local shop. how many of you guys know about the xmods remote control cars at radio shack? well i got one for christmas (god only knows why) but i was looking at upgrades for it and i saw that they have a four wheel drive kit for them. and after hours of configuring, and designing i think that i can build the 4 wheel drive suspension and drivetrain for our robot.
Unread 21-01-2007, 22:01
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
uhh did you just say suspension, as in springs and dampners suspension??
this is a carpeted field were talking about
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 21-01-2007, 23:36
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Do you guys have a shaft coming out of the tranny for the middle wheel as well as 2 sprockets on the inside leading to the front and rear wheels? Are the sprockets inline? Wouldn't you need gears on the same axle as the sprocket to drive the sprockets in that case? Are the sprockets on the same axle? In that case how can your wheels be inline? Are the sprockets on the wheels on an offset?
Alright no more questions just curious.
Unread 21-01-2007, 23:55
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by foundbobby View Post
Nice design. What about having the wheels on the outside? Don't they need be protected some to avoid bent shafts and broken wheels?
Teams have had success with similar designs in the past and our experience with the completed chassis yesterday indicates that, though we may want to protect the wheels, it's not a paramount concern given our strategy and design. In another game, or on another robot, it may be very important that the wheels are protected from damage and from the sort of wedging effect impedes motion that other teams with similar drives have seen in past seasons.
Nice picture! We'll see you at SVR
We hope you'll take a minute and stop by our pit to talk to the team. I'd be happy to talk more about our robot and answer any questions you might have -- as would anyone else on our team. We're proud of the work we do.
The gearbox at the center of each side has an output shaft that drives the center wheel. Two 18 tooth sprockets are coupled to that shaft and, via chain, drive the wheels at the front and back of the robot. Those sprockets are not in line -- they are offset 1/4". Our wheels remain in line because the sprockets on either end mimic the offset of their corresponding center sprocket.
Attached to this post is a cross-section of the gearbox that may help make the gearing arrangement a bit more clear. Excuse that the gears aren't meshed properly, please.
--Madison--
...down at the Ozdust!
Unread 23-01-2007, 10:58
Brian Mocci's Avatar
Brian Mocci Brian Mocci is offline
Still hanging around..
FRC #0195 (Cyber Knights)
Brian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to behold
Send a message via AIM to Brian Mocci
My favorite part about this design, something that no one has mentioned yet supprisingly, is the way that you extended your front and rear rails in order to protect the cantilevered wheels. Excellent design all around!
UTC Regional Champions
2006
UTC Innovation And Control Award
Nationals Innovation and Control Award
Nationals Einstein Runner-Up
pic: 4 Wheel Strafing Chassis Holtzman Extra Discussion 9 08-07-2009 19:28
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
