Go to Post The magic is ALL in the mentors. - AdamHeard [more]
Unread 06-01-2007, 08:49
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: pic: 6 Wheel Drive Chasis
hmmm... 11 hrs. to build and test your prototype. Better hurry!
How are you running the chains? Are all six wheels powered, or are you just powering the center wheels with two CIMs each?
I seriously doubt it will weigh 35 lbs; I estimate between 45-50 lbs., which isn't bad.
Nice work
One of the motors will drive the traction wheel on the end. The other motor will drive the center traction wheel and the omni wheel.
That weighed 35 pounds, but that is without chains, sprockkets, and the iproperties are set to default on the motors. 45 - 50 pounds is proably closer.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
