Go to Post Does this mean the end of "Spin Around/Dance" autonomous modes? - Tom Bottiglieri [more]
Unread 08-01-2007, 04:27
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Risk of the Lift?
With this years game there are two main ideas of how to get the robot up either four inches or twelve inches. They are by ramp or by lifting. For those that are lifting and for those that plan to either climb or be lifted, I believe that the lift is much more dangerous. Although with the ramp you have to to keep it in your base and with 2" of clearance due to bumpers you will need to have a small angle thus a longer ramp, it is much more safer. Your robot is always on solid ground. With the lift you are in the air. Are you sure 30 points is worth the risk of your robot falling twelve inches off of the ground? Although I hope this never happens, I think before teams start thinking of being lifted that they should all consider the possibilities both positive and negative. The main one is a robot falling, and today when my team was discussing this I thought of the fact that if you are being lifted up, you are no longer in control of your robot, and that if anything happens your robot will fall. What if it does? Will your team build a more robust robot that can take a twelve inch fall? Will your team prepare for a worst case scenario?
Before you answer keep in mind that six hard weeks of planning, designing, and building went are going to go into your creation.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 08-01-2007, 05:18
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Risk of the Lift?
Yuu forgot another idea of lifting...
Both a Ramp and a lift, meaning either a robot will be gping up a ramp and then lifted, or one bot goes up a ramp, and another is lifted using an arm...
There are many fine ideas...be sure you think of as many as you can before you decide what you build nd what strategy you are gonna use.
U could also build your bot witha safe lifting system. Its FIRST, everything is possible here. You may even build a chopper
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-01-2007, 05:50
Pavan Dave's Avatar
Busy in College
I am just asking the robots that are going to be lifted, if they know the risks and I am more so asking them if they are prepared for the consequinces of their choices.
Pavan.
1745 - 118 - ΔΕΨ
Unread 08-01-2007, 06:13
Tottanka's Avatar
AKA: Liron Gurvitz
I see what u r asking..
But u make is sound is if each and every liftins system in the game is going to be hazardous, and it will be so in osme cases, but some of them are gonng abe very safe, with not a big risk at all, bout the same risk as there was last year climbing a ramp, maybe even smaller...
I personnaly thing that 30 points are a lot and that it can cahnge the match from side to side...expecially if it's gonna be 60 points =]
Unread 08-01-2007, 07:31
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
And then, at the end of the match, the drive teams who are being lifted all say at once (in a GOVERNATOR voice)- "GET TO ZE CHOPPER!!!"
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 08-01-2007, 07:43
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
In order that robots who want to be lifted at the end of a match, someone should come up with a specification for a standard lifting attachment. This way, teams may design a lifting mechanism that other teams can design for.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-01-2007, 08:02
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
ROTFLMAO!
Nice.
Unread 08-01-2007, 10:57
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
ramp = safe
lift = dangerous
bottom line
also in order to accomodate two robots on a platform it would have to be between 36 and 38 inches wide and 80-86 inches long. This would accomodate for robots with wheels along the short or long sides.
i think we got it. I designed it in inventor and have made a cardboard mach up and today I'm building a half scale model to show at the meeting tonight.
wouldn't 60 points pretty much change the match outcome in most situations?
Unread 08-01-2007, 13:50
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
There are really three methods.
Ramp
Lift from above
Lift from below
I can see lift from below being dangerous because your centre of gravity is above the lifting point and toppling is an issue, but lifting from above should be safe as long as your attach point is solid and they aren't lifting you with silly string.
Ramps are only slightly less dangerous from a toppling perspective. Maneuvering onto a 3ft wide ramp at low speeds will be very difficult for many robots because a motor might stall and all of a sudden they spin and fall off. You can't go at high speeds because you'll damage the lifting robot and also probably fall off. If either your drivers or the rampbots drivers bump their controls, you can easily topple off.
If you're 12 inches off the ground on a ramp, you're just as far up as on a lift. That's just as much robot-destroying potential energy. In either case an accidental movement of either robot might topple you. If you're lifting from above, with a chain, even the lifting robot jiggling might be safe since you you just sway. The lifted robot could do whatever they want.
There were plenty of robots in 2004 that chin-upped without incident despite other robots competing for limited chinup space. Many of them got substantially higher than just 12 inches.
Unread 08-01-2007, 14:03
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Ramp
Lift from above
Lift from below
I can see lift from above being dangerous because your centre of gravity is above the lifting point and toppling is an issue, but lifting from above should be safe as long as your attach point is solid and they aren't lifting you with silly string.
Good Points, Maybe all teams should consider putting a victor brake function in their programming and controls? Just a thought
Eat, Sleep, Build Robots
Unread 08-01-2007, 14:52
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Originally Posted by cgredalertcc View Post
ramp = safe
Hmm, You must have been watching a different competition than I was last year. The number of teams that couldn't climb the ramp surprised me. The number of teams that tried to climb the ramp and fell over astounded me.
Unread 08-01-2007, 14:59
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
It is almost going to be impossible to use a lift to elevate your alliance's robots. It is going to be impossible because pneumanic cylinders are not going to give enough force to exert a lifting device.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 08-01-2007, 15:01
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Now i dont know if this idea is good for use.. But what if you had a bar extend from the "lifter" robot on both sides, and other robots had their own lifting mechanism that would pull themselves up? it would be like 2004, execpt you must make it at least 12" of the carpet.
Unread 08-01-2007, 15:09
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
The only problem is if only one hangs, then they will both tip unless you have a way to stabilize yourself
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 08-01-2007, 15:12
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
This is very true.. that is why team 118 had 2 arms on our robot chainzilla during the 2005 competiton. We had noticed after getting a certain height off the ground that more weight on one side made the robot tip over more so we added a second arm to balance the weight and always made sure that both arms had a tetra on them.
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Risk tournament [527]phil Games/Trivia 1 29-09-2005 17:22
Interface of the window lift motors Marjory Frosty Motors 3 14-01-2005 22:57
PHP as a security risk purplehaze357 Website Design/Showcase 9 02-07-2003 21:50
A little lift for the final week George1902 General Forum 1 11-02-2003 22:48
Amount of Force to lift the bridge? archiver 2001 2 23-06-2002 23:21
