Re: What row will you score on or will you score at all?
Easy, we use Magic. Your team wasn't given that in the kit?
My team uses a little thing called "will power" to score that many that fast.
well still what rows will you score on reasonably with other teams attacking your bot hypothetically defensively and you not being able to stop the other alliance from scoring atleast a few? where will you aim your tubes for. and thanks
Currently it looks like we will either score on or three or (more likely) the bottom two.
Hopefully all 3
We're going for the top 2 =]
We're going for all 3, but can settle for less, if need be.
This question is related to the "how tall/heavy will your robot be" question, and the answer seems to be the same....we'll know when we get there!
Our goal is to score at all 3 levels
#10
Seems like a team who's trying to score the tubes would want to score them wherever would give them the most points. </John Madden>
No, seriously. Where you go for is really going to depend on the match, and where the tubes currently are. |
#11
I dunno, the top 2, I guess.
#12
I think scoring in the middle row would probably be the best position strategically, since you can continue making a vertical row either from the upper or lower "spider leg." Other than that, I'd guess the bottom row.
#13
Our team has an extendable lift which travels 10 feet in the air. We will score on all three levels.
#14
Our team will figure that out when we get the arm finished but as it stands right now our goal is all three.
#15
we're actually going to score every tube. even the ones that aren't ours. We won't be using will power; rather we will be using the magic smoke out of our camera, victors, and other various electronics. Its pretty potent stuff.
| What do you think will happen....? | slickguy2007 | General Forum | 7 | 29-01-2007 18:39 |
| What environment will you use? | Astronouth7303 | Programming | 14 | 09-01-2007 14:58 |
| what do you think high score will be | nuggetsyl | General Forum | 13 | 03-04-2006 14:03 |
| what kind of steering do will you have? | Alex Cormier | Technical Discussion | 2 | 30-01-2004 20:38 |
| SENIORS!! what college will you be attending? | Renzorocks | Chit-Chat | 40 | 05-06-2002 16:54 |
