Go to Post ..attitude and willingness to work as a team...are the qualities that can make or break a team. - Monochron [more]
Unread 09-01-2007, 13:15
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
Re: pic: Encoders and AndyMarks, 341 Style
Originally Posted by dlavery View Post
Al -
I jsut want to check to be sure I am understanding the photo. It looks like the sensor is mounted on a tab attached to the top of the shifting gearbox, and the tab is angled so that the teeth of the gear mounted on the encoder mesh with the driven gear at an angle (i.e. the gears do not mesh across the full face width, but only at the corner of the driven gear). Is that correct? That also appears to be one of the Greyhill encoders. What is the rotational resolution of the encoder you used?
-dave
The answer is yes to the configuration question. We had acceptable contact between the gears, but not great. We saw some wear due to this intentional misalignment, but there was not much force on the encoder gear so it was not too bad.
The answer is also yes to the Greyhill question.
I will have to look up the resolution or ask one of our kids on the programming team. Its probably on the spec. sheet. I am a hopelessly mechanical kind of guy!
I'll ask and report back.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Thanks to Teams 341 and 86! dpraedan Thanks and/or Congrats 1 01-05-2006 00:58
Encoders and putdata theycallhimtom Programming 3 09-02-2006 19:24
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
pic: The Team 341 Jeepinator CD47-Bot Extra Discussion 2 01-11-2004 15:48
thanks to 341 and 204 edomus General Forum 1 29-03-2004 08:17
