Go to Post CNC machine, Something every FIRST kid wants in their bedroom :) - David Kelly [more]
Unread 09-01-2007, 14:48
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: pic: Height on top of a tube
We took plywood and three mentors on a tube and it didn't pop. That would be pretty close to the weight of 3 robots but it was less then 4 inches.
You must have younger mentors - the older ones are correspondingly heavier
If 3 mentors were on TWO tubes laid side-by-side, would they be higher than 4 inches then?
Unread 09-01-2007, 16:22
Onward through the fog.
This is my very first Rack 'N' Roll laugh so hard you get the hiccups quote.
Sad thing is, it's true.
~ Helen Keller
(1880-1968)
Unread 10-01-2007, 11:11
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
As per team update #1
Originally Posted by Section 7.3.6, Rule <G56>
The sentence “ROBOTS score bonus points at the end of the match if they are entirely in their HOME ZONE, not in contact with any element of the field (carpet, alliance station, goal, etc.) and the lowest point of the ROBOT is higher than 4 inches and/or 10 inches above the carpeted field surface” has been changed to “ROBOTS score bonus points at the end of the match if they are entirely in their HOME ZONE, not in contact with any element of the field (carpet, alliance station, goal, etc. - note that for the purposes of this rule, GAME PIECES are considered field elements) and the lowest point of the ROBOT is higher than 4 inches and/or 12 inches above the carpeted field surface.”
So, this would be illegal.
Hmm, now what?
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 10-01-2007, 11:15
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Originally Posted by Brandon Holley View Post
i recall reading a rule in which it referred to the tubes as scoring objects and not part of the field...let me see if i can find it
Just changed in team update.
7.3.6
Not allowed to sit on tube. almost every team hates to hear this
Min-Max to the Max!
Unread 10-01-2007, 13:00
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
<G08> Obtaining GAME PIECES - ROBOTS may obtain GAME PIECES via any of the following methods:Accepting a KEEPER prior to the start of the match as detailed in Rule <G04>Picking up RINGERS from the opposing ALLIANCE HOME ZONE that were placed there prior to the start of the match Grasping RINGERS or SPOILERS that have been placed in the CHUTE by the HUMAN
PLAYER Picking up RINGERS or SPOILERS from the playing field surface
Removing a SPOILER from a HANGING position on the RACK
if a tube is a field element then you could not grab it. do to rule
G33> Field interaction - ROBOTS may push or react against any elements of the field, provided there is no damage or disruption of the field elements. ROBOTS may not grab, grasp, grapple, or attach to any field structure. If a ROBOT violates this rule, the head referee will give one warning. If the referee determines that the TEAM is disregarding the warning, their ROBOT will be disabled for the remainder of the match.
So the tube is a game piece and would fall under those rules and not the element rules.
So if you drop one tube on another, that is not herding because you only had one tube on your robot at a time. then if you climb on one tube you still have not touched both tubes this will get you up over the 12"
unless they make a new rule I think this would work.
"Sorry did not look at the update"
Building FIRST robots since 1995
BVT Robotics
Unread 10-01-2007, 13:03
Elgin Clock's Avatar
FRC #0237 (Black Magic)
7.3.6
And every Referee loves to hear this cause it means less time between matches seeing if a robot is floating at the right height on a tube, and the field reset crew loves to hear this cause this means less chance to break a tube/ less time to reset the field.
Oh well.
Unread 13-01-2007, 01:46
overlord's Avatar
overlord overlord is offline
The Kid With the Jester Hat!
AKA: Clint
FRC #2180 (Zero Gravity)
Team Role: Student
overlord will become famous soon enoughoverlord will become famous soon enough
Send a message via AIM to overlord
Personally, I feel this rule is a good one because it will create less controversy. Plus it will challenge us more to create robots that will be able to get those extra bonus points.
Tube Dimensions JohnBoucher Kit & Additional Hardware 5 18-01-2007 22:16
Vacuum tube. Eric Scheuing Kit & Additional Hardware 11 13-01-2007 14:04
pic: Top Gun Top Wheels Rick TYler Robot Showcase 4 04-02-2006 11:13
pic: 3/4 of our full height Matt_Kitts Robot Showcase 2 23-02-2005 12:20
Dimension Wanted - BOM Caster: floor to top plate surface height kmcclary Kit & Additional Hardware 2 28-01-2004 12:02
