Go to Post Calculate everything. You won't need to make speed holes if you figure it all out beforehand and get it taken care of. - Otaku [more]
Unread 10-01-2007, 16:47
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: pic: Encoders and AndyMarks, 341 Style
Originally Posted by Alan Anderson View Post
You heard wrong. Stop repeating this misinformation. It's only a few hundred characters per second at full tilt.
But the baud rate is still 115k - which is 14400 characters per second (rate). The total number of characters you get in one second is irrelevant, because for the period you are getting a message from the camera you are getting interrupts at that rate if that is the defined serial rate. Over an entire match it may not average this - but average doesn't count for ISR's if when it happens once (say at the same time you are getting a lot of encoder interrupts) when it matters most.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Thanks to Teams 341 and 86! dpraedan Thanks and/or Congrats 1 01-05-2006 00:58
Encoders and putdata theycallhimtom Programming 3 09-02-2006 19:24
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
pic: The Team 341 Jeepinator CD47-Bot Extra Discussion 2 01-11-2004 15:48
thanks to 341 and 204 edomus General Forum 1 29-03-2004 08:17
