Re: paper: Applied Robot Programming for FRC 'bots
Thank you for making this. I know C just fine, and I'm sick of all the "tutorials" on the US FIRST webpage that just go through the basic syntax of C and then leave you to just decifer the default code yourself. This is a God send!
Perhaps considering using open office next time you post something. http://www.openoffice.org/ It is a 100% open source program that uses the Oasis OpenDocument file format, so in the future we won't be stuck using a binary closed file format viewable only by Microsoft programs. Also, it would avoid the problem we're having right now, because Microsoft no longer supports the "Works" file format. OpenOffice can export as a PDF with the click of a button, so anyone can view it, even those of us not willing to spend >$90 on Microsoft Office. |
| White Paper Discuss: C Programming and Autonomous Modes for Newbies | cbolin | Extra Discussion | 3 | 09-01-2008 19:32 |
| paper: PID Control Theory for FRC Programming | Matt Krass | Programming | 17 | 24-05-2007 03:28 |
| VEX Limit switches for FRC Robot??? | cdennisxlx2 | Technical Discussion | 5 | 18-11-2006 13:37 |
| White Paper Discuss: An Introduction to C Programming for FIRST Robotics Applicatyions | eugenebrooks | Extra Discussion | 2 | 01-01-2006 15:51 |
| White Paper Discuss: An Introduction to C Programming for First Robotics Applications | CD47-Bot | Extra Discussion | 10 | 26-11-2004 21:54 |
