Go to Post What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
Unread 11-01-2007, 13:35
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
Tracks or Wheels?
Has anyone used tracks before? If so can I please have some help finding the equipment for that. thanks!
Unread 11-01-2007, 13:40
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Re: Tracks or Wheels?
Team 195 used tracks for the past few years and now their quality has decreased and we are now going to use a six wheel design because of the lack of reliability of tracks.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 11-01-2007, 13:49
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
My understanding is that tracks, while great for stability, are not so good on turning and drain the battery pretty quickly when making a lot of turns. If you'd like to pursue it, I think most teams use belts from McMaster-Carr for their treads.
Hi!
Unread 11-01-2007, 13:51
pfreivald's Avatar
AKA: Patrick Freivald
Last year we 'simply used' (hah!) a four-wheeled system with two of the IFI traction wheels chained to the kitbot transmission -- it worked great at school on the gym floor, but when we went to the Rochester Rally (thanks again, 1511! You rock!) we found that we had so much traction we couldn't turn, and had to do a big re-design.
I can imagine that tracks could easily experience a similar problem.
Patrick Freivald -- Team 1551
Unread 11-01-2007, 13:59
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
365 had tracks on their '05 bot, look on their site for pics.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-01-2007, 17:45
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Look through the FIRST Mechanism Library to get some ideas. Good luck.
Unread 11-01-2007, 18:03
Brian Mocci's Avatar
Brian Mocci Brian Mocci is offline
Still hanging around..
FRC #0195 (Cyber Knights)
Brian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to behold
Send a message via AIM to Brian Mocci
BRECOFlex is a fairly commonly used vendor by FIRST teams for tank treads, check out their website here http://www.brecoflex.com/
Heres a pic from team 195's '04 robot which incorporated modular track assemblies LINK
UTC Regional Champions
2006
UTC Innovation And Control Award
Nationals Innovation and Control Award
Nationals Einstein Runner-Up
Unread 11-01-2007, 18:20
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
The trick with tracks, especially when it comes to turning is to make sure there is a slight pivot point at about the middle of your track setup. It allows for much smoother turning.
Team 703 has used tracks for several years now and the only problem we ever run into is breaking the track. We've improved upon the system to help prevent this, however this year we're working on a totally revolutionary drive system. I'll probably post some pictures after the build season, as it is currently "Top Secret".
Unread 11-01-2007, 19:59
3@G13_1388's Avatar
3@G13_1388 3@G13_1388 is offline
FRC #1388
3@G13_1388 is an unknown quantity at this point
awwwwwwwww plz tell us or at least give us a hint
Unread 11-01-2007, 20:02
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
lopz056 is an unknown quantity at this point
well i wouldnt consider using treads for your robot because of reliability issues, and when you make a turn theres a chance of the tracks slipping off, but if you already have that design in mind, it would probably be a good idea to use belts other than treads, and theres always the issue of draining the battery with treads.
Unread 12-01-2007, 00:08
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Naw, you wanna talk draining batteries, last year we had all 6 CIM motors on our drive train! That thing had power but changing the batteries after every match was a must!
You want a hint? Ok, fine this is all I'm giving you...
Remember how I said breaking treads was a problem for us? Well we've found a way to create a drive system that simulates the effects and advantages of treads without the possibility of breaking or falling off like a tread.
Feel free to post an guesses you may have.
Unread 12-01-2007, 00:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Omnitreads just has to be the answer!
Okay, seriously, my vote goes with wheels over tracks for this year's competition. Every team that I have seen with a tracked robot ( except 753 in 2004...) have a very difficult time turning from all the lateral friction. Wheels are easy to set up and easy to design around, which is why we'll be going that way this year.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 12-01-2007, 09:34
Custom User Title
Send a message via AIM to Tom Bottiglieri
I think instead of asking "should we use treads or wheels?", you should first establish what you want your end functions to be.
Ask questions like:
"How important is turning on a dime?"
"How much weight will we have?"
"What do we have the resources to build succesfully?"
"Would we rather be powerful or agile?"
After you set up what you want your robot to do, your design choice will pretty much fall into place. You can use some tools such as a decision matrix to further investigate what the best design for your application is.
Remember, let function drive design, not the other way around.
Team 254 | San Jose, CA | Mentor (2010 - Present)
Team 125 | Boston, MA | College Student (2007 - 2011)
Team 195 | Southington, CT | Student (2002 - 2006)
Unread 12-01-2007, 09:55
Brandon Holley's Avatar
Ask questions like:
Thats right you put the GEU111 into good use!
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 12-01-2007, 10:07
Custom User Title
Nah, I got my roots in FIRST and PLTW. There's alot of good resources out there for teams to use to prepare themselves for the build season. Conferences from the championship event and kickoff workshops are all online. Use them.
do tracks and wheels together make a better robot? gondorf Rumor Mill 31 16-01-2006 16:06
Tank tracks vs. Wheels MBosompra Technical Discussion 28 16-01-2004 23:31
Where Can I Get Some Wheels Or Tank Tracks? Alex Cormier Kit & Additional Hardware 5 13-01-2003 22:58
Tracks archiver 2001 2 23-06-2002 22:59
Beatty tracks JamesJones Technical Discussion 24 11-04-2002 13:33
