Re: pic: 6WD Module
You get more contact area between the drive wheels and the carpet when you use more wheels.
Some will argue that the reduced weight on each wheel makes it no more effective than a four-wheel system. Others will counter with the idea that the carpet fibers bend and thus have a maximum static friction force they will support for a given area. |
| pic: Completed Mecanum Module | Madison | Technical Discussion | 9 | 12-11-2006 19:39 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
| 6WD? | Alex Cormier | FIRST Tech Challenge | 14 | 17-04-2006 22:10 |
| pic: 494 Power Module | KEY | Extra Discussion | 14 | 26-01-2005 17:50 |
| pic: Tytus's Coax Crab Module | CD47-Bot | Robot Showcase | 8 | 17-11-2003 10:08 |
