Go to Post Isn't that what we do here? It seems like no 'controversial' thread is complete until everyone gets a say. - kjohnson [more]
Unread 12-01-2007, 19:26
RogerR's Avatar
RogerR RogerR is offline
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Re: pic: Basic chassis done
Originally Posted by cinderblock View Post
...So why extra wide wheels in the back?
one upside of having a large surface area is that the traction material will wear more slowly than a narrower wheel; more surface area means the forces are more widely distributed.
Also, while friction is not dependant on surface area, traction can be, under the right circumstances. for example, back in 2002 when you where allowed to lift 180# goals, teams would often tear up carpet fibers; the teams with narrow, high traction tires more than those with larger surface areas. by increasing the contact area, you spread the force around, so an individual carpet fiber is less likely to fail. more surface area, more carpet fibers sharing a given load.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 12-01-2007, 23:09
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
You guessed it! It keeps us from having to repair the treads on the IFI wheels, we saw teams having to fix them frequently, last year we used this setup and never repaired one! Even though calculations show we loose some traction, we have not had a problem pushing everybody around. Plus it just plain looks cool!
Faridodin "Fredi" Lajvardi KD7WKD
pic: Top Chassis Rick TYler Robot Showcase 1 04-02-2006 19:13
pic: 1018 - Pic 4 - Welded Chassis Stu Bloom Robot Showcase 17 03-02-2006 21:36
pic: 195 Chassis Tom Bottiglieri Robot Showcase 14 09-02-2005 11:16
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
basic chassis (the supplied one) diagrams and directions Andrew Dahl Technical Discussion 7 15-01-2004 19:59
