Re: pic: 931 Preliminary Electrical Layout
are you using the plywood for your final board? we've saved a lot of weight in the past few years by using 1 or 2ply of hand laid fiberglass on both sides of a balsa core. it weighs almost nothing and is strong enough for a electronics board.
We have not used plywood for the electrical system board in previous years and probably won't this year either. Usually we have laser-cut 0.22" thick acrylic sheet. Wood is nice and forgiving though, and will let us experiment with layout ideas until we feel comfortable. A factor to consider is that the kitbot frame needs some stiffening anyway, so our choice for final electrical board material may be based partly on overall robot strength requirements, not just being "strong enough for an electrical system". Sometimes adding weight to one subsystem lets you take even more weight out of another. |
The connectors on those speed controllers(red/black)...They seem very nice...look like mini battery connectors and easier than two quick disconnects terminals. Where did you get those?
Good luck this season. ![]() |
I'm still not sure whether we can use the negative stud in power distribution. Can anyone give a definite answer?
That electrical layout looks very nice you guys. Great job!
Richard,
Looks really cool, nice job! I would eliminate the ground stud and return the negative leads directly to the distro block. You save some weight in #6 and crimp on connectors and lower the series resistance, not to mention a single point failure if the stud hardware loosens. How do you like the crimper and the Power Poles so far? We add a touch of solder to the connector just to be sure, before assembly. They crimp on the #12 Chalupa leads OK as well, but again a touch of solder just to be sure. |
Thanks, Al.
We will probably lose the stud when we compact the layout somewhat -- right now the footprint is still too large. I agree the stud takes up valuable space and is an extra failure point. Also, I am not sure that the stud is a COTS component. It was in an old (2003? '04?) KoP but I don't think it was custom made for FIRST. Anyway I would need to get a part number and price to show for material cost analysis if we want to use it on the robot. |
Richard,
It seems to me that they were available from Terminal Supply that year. |
#10
But it does seem to be available at Hot Rod Wires. |
| IRI Schedule - PRELIMINARY | Chris Fultz | Off-Season Events | 4 | 05-07-2006 21:05 |
| pic: Team 931 Summation | RebelWithARobot | Extra Discussion | 8 | 10-05-2006 11:10 |
| Team 810: Electrical Layout, rev 1 | ForgottenSalad | Robot Showcase | 4 | 04-02-2006 00:03 |
| Team 931 Omniwheels | bheller | Robot Showcase | 7 | 19-02-2004 23:56 |
| Electrical wiring layout sheet | George T | Electrical | 1 | 11-02-2003 18:20 |
