Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 12-01-2007, 23:38
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: pic: Team #8's Tube Interface
That's the $1,000,000 question. Since we're still at the prototype stage, we haven't moutned the whole thing, and haven't tested it. We'll have to see soon. Hopefuly it does it easily enough to write simple code or have the arm driver do it himself.
Originally Posted by Alekat View Post
I assume with those two wheels you could also rotate the tube in your grabber by running them in opposite directions?
I must say it's brave of you to be putting up a prototype for widespread speculation. And on that note, have you thought about interference from the huge flange? Or do these two wheels mean to sort of project the tube a short distance?
Exactly. That's the main benefit we see from this desgin - we'll have a lot more control without adding an extra degree of freeedom on the arm.
We decided to to put it up, and here's why: If someoen does copy it, which is against GP and unspoken code, he'll not do it as well as we do, because we designed it. If we help someone, good for them and good luck in competition. Otherwise, we're just proud of our work and showing it!
-Guy
Vacuum tube. Eric Scheuing Kit & Additional Hardware 11 13-01-2007 14:04
pic: Height on top of a tube Jeff Rodriguez Extra Discussion 21 13-01-2007 01:46
pic: Team 228 Operator Interface artdutra04 Robot Showcase 7 11-03-2005 21:41
pic: Portable Power Pack for Operator Interface CD47-Bot Extra Discussion 13 19-07-2004 03:02
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
