Go to Post The Robot Alliance Project is perpetrating the government shutdown? I KNEW robots would take over the world! - BBray_T1296 [more]
Unread 15-01-2007, 19:23
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
pic: Dawgma 1712 as of 1-15-07
Unread 15-01-2007, 19:24
Nate Laverdure's Avatar
FRC #2363
Re: pic: Dawgma 1712 as of 1-15-07
What size 80/20 (or Bosch) is this? Looks very nice! Good work!
Unread 15-01-2007, 19:25
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
looks stout.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 15-01-2007, 19:30
Gone Fishin'
nate: we're using 1"x1" 80/20.
Unread 15-01-2007, 20:04
in between teams
AKA: Luke Van Oort
What made you decide to go with a 4WD instead of a 6WD like last year?
Team 1219: 2009 - Mentor
Unread 15-01-2007, 22:12
Gone Fishin'
Luke: Why we decided not to got with a 6 wheel drive like last year is because of a few reasons. One being that there is no guaranteed ramp at the end of each match, however the most influential one was the fact that our method for a 6 wheel drive last year was very finicky. The tensions of all the chains we interdependent, so if the front most was too tight, the rear most was too loose, and vise versa. Using just 4 allows us an easier way to adjust the chains and have a lighter drive base that is just as powerful. Also, if we do eventually need to add 2 more wheels to our bot for some reason, we can just slide the bearings into place easily.
Unread 16-01-2007, 06:56
sea_master's Avatar
sea_master sea_master is offline
AKA: the $@#$@#$@#$@#$@#$@# guy
FRC #1947 (the black knights)
sea_master is on a distinguished road
Send a message via ICQ to sea_master Send a message via MSN to sea_master
i c that u guys used the gear box from last year.. is that legel?
Unread 16-01-2007, 07:04
Billfred's Avatar
Billfred Billfred is offline
That's not the same gearbox--it's an AM Gearbox from AndyMark, which is similar (but not the same).
Unread 16-01-2007, 11:08
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Indeed. It runs quieter than the 2006 kit gearbox and has some other differences as well
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 16-01-2007, 12:00
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
i bet it runs quieter! the 2006 kit gearbox was loud as heck, even after we removed the crushed metal bits. i miss the old gearbox though - have you found the andymark one to be as robust? i feel like the banebots planetaries are a little wimpy compared to last year's box.
Unread 16-01-2007, 16:29
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
If you are removing center wheels from a 6-wheel design, then make sure your 'bot will be able to turn. Basic rule of thumb: If the distance between wheels side to side is greater than the distance between wheels front to back, then you are OK. If not... consider a change.
Good Luck!
-Mr. Van
Coach, 599
The RoboDox
Unread 16-01-2007, 17:15
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
I miss 80/20. The team I'm mentoring doesn't use it.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 16-01-2007, 20:11
Gone Fishin'
They seem to run nicely on our bench tests, however I can give you a better idea after we start driving the bot around sometime this week.
Unread 16-01-2007, 21:08
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
With the top row of extrusion, electronics, and chain, this will weigh 58 lbs.
I think it'll work, but we'll see tomorrow. If we have to, we can exchange wheels for casters.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 03-02-2007, 12:43
Good Luck!
-Mr. Van
Coach, 599
The RoboDox
Mr. Van,
We don't quite meet the rule of thumb (side to side is about 23", front to back is about 27"), but we did more than simply reorient and remove two wheels. Our sprockets/ratios are different, our gearbox went from the 2006 kitbox to the AM single speed and is repositioned, the way we chain/connect has been revised, etc). Since week two we've been testing on carpet at 120+ lbs and are doing fine.
We're still running fine with the setup and the AM singles seem plenty robust in our testing. While this isn't on carpet and isn't with our extra weight (ramp/platform to come), this should give you a little idea of where we are... http://video.google.com/videoplay?do...860&q=FRC+1712
We'll shoot some more video on carpet in more space next week to show those that are interested in the AM single speed.
pic: 1712 Defends Center Goal Chuck Glick Extra Discussion 5 24-10-2006 20:38
pic: Team 1712's Dawgma I on the Truck IraJason Robot Showcase 5 21-02-2006 21:10
pic: Team 1712 First Test IraJason Robot Showcase 3 15-02-2006 14:18
pic: Team 1712 Robot! IraJason Robot Showcase 9 09-02-2006 21:54
pic: Team 1712 Robot! IraJason Robot Showcase 3 04-02-2006 13:31
