Go to Post Ask the right questions and you can get the right answers. - Chief Hedgehog [more]
Unread 17-01-2007, 00:36
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: mounted Anderson
You sure its okay with FIRST that you screw things into the battery plastic?
I love the way it just clicks in, but I would have used epoxy or some other kind of adhesive instead.
(It seems screwed to the battery to me.)
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 17-01-2007, 00:54
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
If that's attached to the battery, it's illegal per <R65>.
Originally Posted by <R65>
The control system is provided to allow wireless control of the ROBOTS. The Operator Interface, Robot Controller, speed controllers, relay modules, radio modems, batteries, battery charger, AC adapter, and 9-pin cables can not be tampered with, modified, or adjusted in any way, (tampering includes drilling, cutting, machining, gluing, rewiring, etc.) with the following exceptions:
  • Dip switches on the Operator Interface may be set as appropriate.
  • User programmable code in the Robot Controller may be customized.
  • Speed controllers may be calibrated as described in owner's manuals.
  • The fuse on the Spike relay for the air compressor may be replaced with a 20 Amp Snap-Action circuit breaker.
Is the battery held in only by the Anderson connector? That wouldn't be sufficient—that battery desperately needs to be secured, to avoid it coming loose. (Consider what would happen if your robot were flipped.) Also, it might not be a great idea to put such sharp bends in the 6 AWG wire at the base of the Anderson connector (that will just increase the resistance and cause it to heat up, wasting energy in the process).
Unread 17-01-2007, 01:09
Elgin Clock's Avatar
FRC #0237 (Black Magic)
The Good:
The Anderson quick disconnect was not tampered with in any way possible.
The quick disconnect housing has 2 holes in the center of it already.
Since they did not drill, machine, or otherwise into that part, it would be legal and I've seen this done hundreds of times with many teams before with no problems.
The Bad:
I do agree some more needs to be done to hold the battery down though. Maybe a velcro strap, or something. Anything.
Unread 17-01-2007, 01:16
It's not the Anderson connector that I'm concerned about modifying (though that's not necessarily a great idea either). It's the main battery. Those screws look like they're in the top of the battery, probably in the cutouts beside the vent cap cover. If it's just sitting there, and the screw heads are just for decoration, I could see it being legal—but what are the chances of that?
And yes, I do realize that drilling through that thin flange probably won't be a hazard. But the slightly increased possibility of a stress fracture or some other gruesome fate precludes that sort of modification, no matter the location. I don't think FIRST will look fondly upon this modification, but go ahead and ask the Q&A for permission (describing specifically why this is a safe modification in your opinion), because I know you don't want to have to buy new batteries to replace the modified ones.
Unread 17-01-2007, 07:40
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
I don't know for certain, but that metal bracket could just be glued on. 842 has attached handles to their batteries for a couple of years now (pretty sure they're glued), and I don't believe they've had problems passing inspection anywhere before.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 17-01-2007, 09:17
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Inspectors sometimes make mistakes due to oversight or incomplete understanding of the rules. I've done it, and was lucky to have someone around who caught what I missed.
Gluing components to the battery is not allowed per <R65>. Similar rules have disallowed this in previous years also.
Richard Wallace
since 2003
Unread 17-01-2007, 09:59
In any case, if you look at the other picture that they posted, it's definitely screwed through* the battery.
*Remember the old joke about drilling holes in the battery (to lighten it, back in the days when the battery counted toward the robot's weight)?
Unread 17-01-2007, 10:24
Oh.. through the handle.
Meh. I guess it's a good thing I'm not an inspector then, cause I would let that go.
Unread 17-01-2007, 10:38
Elgin, I understand your feeling there. The location of those holes in the battery case is not as dangerous as some other possibilities. Sometimes when a rule violation seems unimportant we are tempted to let it pass. However, as Dave pointed out recently, it is not a robot inspector's prerogative to apply the rules selectively. That would be the same as making a new rule, and making rules is the GDC's job.
In this instance, stress transferred to the battery case through the drilled handle (e.g., due to shock loads when the robot hits something, or by installing a new battery in a hurry) may be outside of the limits considered by the battery's manufacturer when they designed the case. So my opinion is that <R65> makes sense as applied to this situation. But really my opinion about the rule doesn't matter; the rule is there and as an inspector I have to note the violation, and require the team to correct it before their robot can pass inspection.
Richard Wallace
since 2003
Unread 17-01-2007, 14:09
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Would attaching sticky back velcro to the battery be considered a modification?
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 17-01-2007, 16:33
Do we all have small hands or something? I can pick up the battery with no problem just as it comes. If you can't use both hands. If you don't have two hands free, grab a team mate. It is a probably a good idea to assign one person to be in charge of the batteries anyhow.
Unread 17-01-2007, 20:18
mizscience's Avatar
mizscience mizscience is offline
your friendly geek-next-door
AKA: Melissa Smith
FRC #1251 (TechTigers)
mizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of light
No, as that is you adding something to secure the battery, not you trying to permanently attach it to the robot or screwing into it or some other such modification.
Once a TechTiger, always a TechTiger.
@mabsmith
Currently a PhD student in VA, volunteering at the DC/FL Regionals and Championships.
16 years and counting with FIRST! FIRST changed my life; how's it changing yours?[/size]
Unread 17-01-2007, 22:21
DonRotolo's Avatar
Back to humble
FRC #0832
Hey, at least they find out NOW that it's not allowed, rather than at inspection.
Telling them is GP.
Don
How is your camera mounted? bear24rw Programming 19 16-03-2006 12:36
pic: 1559 Turret mounted bradleym1559 Robot Showcase 2 04-02-2006 09:14
Backwards Mounted Motors Mike Programming 11 22-06-2005 16:21
Electronics mounted on metal Nitroxextreme Control System 3 01-02-2005 22:42
Can the Cameras be mounted Sideways? vicecityman666 Technical Discussion 1 29-01-2005 10:21
