Go to Post I check Chief Delphi more often than I check Facebook and Twitter combined. It's probably unhealthy actually... - Ginger Power [more]
Unread 17-01-2007, 15:03
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: 1683 2007 drivetrain
Unread 17-01-2007, 15:04
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: pic: 1683 2007 drivetrain
What is your ground clearance? It's kind've hard to tell if it's raised up or really low from this angle. I'd just make sure you have enough clearance to get up steep ramps since you don't know what size ramps teams will be creating (and even if you plan to add a ramp of your own you should just make sure you plan for going up others just in case a match would want that).
Chopsaw? Chopsaw.
Unread 17-01-2007, 15:07
AKA: Sean
Ground clearance is at about 1.5". We will definitely be able to get up ramps and will probably have a ramp/lifting device of our own. We are pretty low overall though. Those are 5" wheels.
Mentor 2415
Unread 17-01-2007, 15:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
What transmissions are you using to drive your wheels? It's hard to tell from this angle.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-01-2007, 15:35
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Looks pretty cool. Could you explain how the arm mechanism works?
-Guy
Unread 17-01-2007, 15:49
Nate Laverdure's Avatar
FRC #2363
Are those the 80/20 linear bearings on your arm? How well do those work, as compared to other methods of lifting multiple-stage arms?
Unread 17-01-2007, 16:09
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I trust the frame actually will be pink in reality as well.
I'm going to echo Cory's question about the transmissions, as well as inquire where your chain runs will be.
Also, where are you locating your electronics?
Unread 17-01-2007, 16:49
AKA: Sean
We are using the Andymark 2 speed transmissions. For the wheels we are using 5" colsons with live axles. The middle and rear wheels will be driven off of the transmission and then a chain will run from the middle to the front wheel. Those are the 80/20 linear slides. As for how well they work we have never tried them, but I have seen them used many times and they seem to work really well for a pretty low cost and no machining. The frame will most definitely be pink. I actually talked to the powdercoater earlier this week and we should have something worked out with them. The electronics will be in the far rear and the front section around and under the arm.
Mentor 2415
Unread 17-01-2007, 17:13
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
Will the arm be chain driven?
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 17-01-2007, 17:32
AKA: Sean
Right now it is chain driven. We will have to see how we are doing on weight though.
Mentor 2415
1683 Pink Beast at competition sdcantrell56 Robot Showcase 5 10-04-2006 14:09
pic: 1683 Robot Pre-Competition sdcantrell56 Extra Discussion 1 22-03-2006 19:29
pic: BOB's Drivetrain Hoshua2nd Robot Showcase 19 01-03-2006 10:29
pic: 254 Drivetrain CD47-Bot Robot Showcase 41 05-05-2004 09:36
pic: drivetrain CD47-Bot Robot Showcase 3 07-03-2004 20:35
