Re: pic: new battery mount
Fredi,
Looks good. I caution teams about severely bending the #6 near the Anderson connector. The sharp bends close in, can cause individual strands to break or pull out. I suggest 1" minimum bend radius when close to the connector. |
All cable has a spec sheet with a minumum bending requirement that should be followed as closely as possible. I'll see if I can pull some data up for the specific type of cable used on the Anderson quick disconnect if I can. |
Brilliant use of the butterfly clip for fast release! I may take a page out of your book on that one.
Thanks for the heads up, we will check them.
| New Battery | Andy Brockway | Kit & Additional Hardware | 10 | 31-01-2007 17:51 |
| pic: 862 Radio Mount | Joe J. | Extra Discussion | 7 | 13-03-2006 02:09 |
| pic: Main drive mount | falconmaster | Extra Discussion | 2 | 18-01-2006 20:05 |
| pic: AM shifter mount close up | falconmaster | Extra Discussion | 2 | 18-01-2006 19:27 |
| pic: 1351 camera mount | sciguy125 | Robot Showcase | 6 | 05-02-2005 09:11 |
