Go to Post I've be addicted for 15 years. Tried to quit but failed. - Gdeaver [more]
Unread 18-01-2007, 10:33
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: new battery mount
Originally Posted by Al Skierkiewicz View Post
Fredi,
Looks good. I caution teams about severely bending the #6 near the Anderson connector. The sharp bends close in, can cause individual strands to break or pull out. I suggest 1" minimum bend radius when close to the connector.
Working in the industry in place that makes connectors and cable assemblies, and more specifically in a cable engineering department, I can respect and second that suggestion!!!
All cable has a spec sheet with a minumum bending requirement that should be followed as closely as possible.
I'll see if I can pull some data up for the specific type of cable used on the Anderson quick disconnect if I can.
Unread 18-01-2007, 13:55
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
Brilliant use of the butterfly clip for fast release! I may take a page out of your book on that one.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
New Battery Andy Brockway Kit & Additional Hardware 10 31-01-2007 17:51
pic: 862 Radio Mount Joe J. Extra Discussion 7 13-03-2006 02:09
pic: Main drive mount falconmaster Extra Discussion 2 18-01-2006 20:05
pic: AM shifter mount close up falconmaster Extra Discussion 2 18-01-2006 19:27
pic: 1351 camera mount sciguy125 Robot Showcase 6 05-02-2005 09:11
