Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
Unread 19-01-2007, 02:14
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: pic: 6 Wheel drive Rh side
What you can't see is an idler hidden by the top frame rail that wraps the chain more around the top in addition to what you see of the bottom of the sprocket . Almost 50 percent of the sprocket's teeth are in contact with the chain. The final drive ratio is 22:1 and it can push rather nicely.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
