Go to Post CD, you are crazy!!! - Tottanka [more]
Unread 19-01-2007, 08:35
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: 6 Wheel drive Rh side
Originally Posted by NOV8R View Post
What you can't see is an idler hidden by the top frame rail that wraps the chain more around the top in addition to what you see of the bottom of the sprocket . Almost 50 percent of the sprocket's teeth are in contact with the chain. The final drive ratio is 22:1 and it can push rather nicely.
Judging from the picture, there is only about 45 degrees worth of chain wrap around that center sprocket. At the very least, you should always have at least 180 degrees of chain wrap around a sprocket. In a high torque application such as a drivetrain, you're much more likely to skip teeth on the sprocket if you do not have adequate wrap of the sprocket.
Art Dutra IV
世上无难事,只怕有心人.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
