Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 19-01-2007, 09:15
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Re: pic: 1881 tube interface idea
In addition to the other ideas,
you could simply attach a pneumatic cylinder to the back of finger supports or you could use the same cylinder to pull the wire that edthegeek proposed. pneumatics are usually the way to go for grippers because they don't loosen or back drive when they apply force.
just my thoughts
2004 - 2012: Team 1100
2013 - ????: Team 131
pic: Team #8's Tube Interface dfukuba Extra Discussion 5 13-01-2007 02:04
pic: Height on top of a tube Jeff Rodriguez Extra Discussion 21 13-01-2007 01:46
pic: Team #8's Tube Interface dfukuba Extra Discussion 13 13-01-2007 01:16
pic: 1881 new gearbox design GMAdan Extra Discussion 7 21-12-2006 01:59
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
