Go to Post when things start to get a little stressful, "FIRST: Fun Is Required. So Tolerate!" - Rich Kressly [more]
Unread 19-01-2007, 11:45
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: pic: 6 Wheel drive Rh side
Dan and Gus you're both right. Yes, the chain meshes on both sides of the sprocket and the sprocket on the transmission is in the position of the second idler Gus shows. There is no chain/sprocket contact that is less than 120 deg of circumference. In fact both end sprockets are almost 240 deg. We played around with many designs for a single chain six wheel drive during the off season and this one is the one that met our requirements (reliable, durable, and simple). We've run it and this design seems to be nuke proof. However, the true test will be on the field with other robots.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
