Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 19-01-2007, 08:21
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
pic: XBot 2007 electronics panel
Unread 19-01-2007, 08:28
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
Re: pic: XBot 2007 electronics panel
Very Nice. Looks good. I like the way you are saving weight by cuting out the center of the speed controlers. May i ask what type of material your using to mount everything to.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 19-01-2007, 08:35
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
It is ABS 1/4" plastic. We might still take some weight out of it, if we have time to take the electronics off and cut it before the panel is needed on the robot.
Unread 19-01-2007, 08:49
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
I like the neatness of the wiring. No access wiring to get caught up in the moving parts of your robot or someone elses. Plus the amount of weight your saving by cutting the excess wiring.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 19-01-2007, 09:30
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
Every year that I been on a team the wiring was dealt with as a last priority, causing many unexpected failures that were very difficult to diagnose and fix. We finally decided that we would do it right this year
I will post a picture when the board is more finalized.
Thanks!
Unread 19-01-2007, 10:33
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
I like the short runs of #6 and the central location of the blocks and Main breaker. The output of the main breaker must feed the distribution blocks before the fuse panels per the wiring diagram and Tips and Guidelines and
<R57> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit breaker distribution panels must be connected as shown in the 2007 Power Distribution Diagram.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 19-01-2007, 10:48
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
Thanks, and yes - we were already discussing whether that was acceptable or not. Thanks for pointing out the specific rule though!
Unread 19-01-2007, 10:50
Anytime!
Glad you were able to catch it early.
Al
WB9UVJ
www.wildstang.org
Unread 19-01-2007, 15:25
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
what fasteners are required for mounting the electrical hardware to a flat panel? Is it provided in the KOP?
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 19-01-2007, 15:27
Joel J's Avatar
Joel J Joel J is offline
do you..
Joel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond repute
How much does your electronic panel weigh, with all the victors, and etc?
Joel Johnson
Division By Zero (229) Alumni, 2003-2007
RAGE (173) Alumni, 1999-2003
Unread 19-01-2007, 16:15
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
We are just using standard #8-32, #10-32, and 1/4"-20 bolts for mounting, and zip ties for the speed controllers. It is stuff not generally supplied. (I know there are zip ties in the KOP, but I am not sure about any other appropriate hardware).
We will weigh it tonight...
Unread 19-01-2007, 16:30
dtengineering's Avatar
AKA: Jason Brett
Looks nice... I've found that #8 nylon machine screws and nuts save some weight over steel screws and also provide one less conductive surface to short out to.
See you in Portland.
Jason
Unread 19-01-2007, 18:11
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Very nice job. I just wish they'd come up with something better than the maxi block for the 40 amp circuits. It's the most ridiculously heavy breaker block I've ever seen. I think the 4 position maxi block weighs more than the entire '05-'06 IFI breaker panel. I don't know why more teams didn't use the IFI panel (other than size, which wasn't that bad, and maybe too many 20-30 amp circuit slots).
Wouldn't it be nice if they came out with the DIN rail product to accept the breakers? That would kill two birds with one stone, and I think the DIN rail is even lighter than the maxi blocks and it's handling the entire 120 amp load.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 19-01-2007, 21:19
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Very nice you guys!
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 20-01-2007, 19:41
Sharkbyte's Avatar
Sharkbyte Sharkbyte is offline
Electronics & Webmaster
AKA: Eric Jonardi
FRC #1732 (Hilltoppers)
Sharkbyte is on a distinguished road
Send a message via AIM to Sharkbyte Send a message via MSN to Sharkbyte Send a message via Yahoo to Sharkbyte
For each of the four victors you have a single wire coming out of the DIN block ports. You can combine them:
Battery Power Distribution Terminal Strip Manual:
Maximum Wire Size and Max Quantity Allowed per 1492-J16xx Terminal
1 - #6 or
1 - #8 or
2 - #10 or
3 - #12 or
4 - #14 or
4 - #16
"I have gone to find myself. If I get back before I return, keep me here."
"Duct tape is like the force: It has a light side and a dark side and it holds the universe together."
"If duct tape isnt the answer you're looking for, you're asking the wrong question."
"You only need 2 things in life: WD40 and duct tape. WD40 for the things that don't move that should, and duct tape for all the things that do move but shouldn't."
pic: Tin Cans 2158 Electronics Box 2007 lynca Extra Discussion 15 20-01-2007 02:03
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 22-11-2006 09:21
pic: Xbot vs. Cheesy Poofs, Round 2. Madison Robot Showcase 16 27-10-2006 00:18
pic: FRC 488 - XBot - Hex Madison Robot Showcase 5 21-02-2006 19:30
pic: 461 Electronics Logan Byers Robot Showcase 9 13-02-2006 06:39
