Go to Post I like what FIRST said about it best: They consider it part of the "Game Challenge" - Alavinus [more]
Unread 20-01-2007, 23:18
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
pic: Servo Controlled Valve
Unread 20-01-2007, 23:20
Nate Laverdure's Avatar
FRC #2363
Re: pic: Servo Controlled Valve
Interesting and novel idea, but I can't think of a use for it.
And does this violate <R99> (customizing pneumatics components)?
Unread 20-01-2007, 23:23
Darkforces's Avatar
Darkforces Darkforces is offline
Froforces
AKA: Taylor Burch
FRC #1875 (Autonomato Atonamatons)
Darkforces will become famous soon enoughDarkforces will become famous soon enough
Send a message via AIM to Darkforces
nice
Unread 20-01-2007, 23:24
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
my guess is that it open the value to empty the pneumatics system instead of doing it by hand
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 20-01-2007, 23:26
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
My best guess at an application would have to be some sort of cut off valve to lock in a vacum....seems like a solenoid would also provide the same effect
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 20-01-2007, 23:27
in between teams
AKA: Luke Van Oort
I'd guess it is for controlling vacuum. I'm surprised the servo has enough torque, those valves can be sort of sticky.
Team 1219: 2009 - Mentor
Unread 20-01-2007, 23:29
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
would this work as a variable solenoid of some sort?
Unread 20-01-2007, 23:33
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
Maybe it dumps the system to let down the ramp instead of using a solenoid to extend or retract a piston if its a one shot deal. Though i dont think thats legal is it?
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 20-01-2007, 23:59
kmcclary's Avatar
Rookie Year: 1994
NO. No modification of the valve occurred. It is simply a "knob turner". The valve's knob was NOT modified, and it is retained within the box only via the SMC connectors (no leaks!).
Gee... I see that CDF put the pic up before I had a chance to add my comments. (Wow! 99 views already while I typed!) Please look at the text now supplied, for construction and usage notes.
I hoping that this design may be found useful for:
-- a rookie team with limited budget for real control valves,
-- someone wishing a non-piloted valve for vacuum or low pressure cylinder apps (below what kit valves can control),
-- a team that wishes to make a Starting-to-Operating configuration transformer setup, without wasting an expensive kit valve for the purpose,
-- any application where you need to isolate a subsystem (IOW prevent something from working) from start of round until the desired critical moment, or
-- stopping a cylinder in a mid-position, by plugging the vent port.
BTW, if you DO replicate this in some version, PLEASE drop me a note to tell me your mods, and how you used it! Good luck with your build!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 21-01-2007, 00:12
kmcclary's Avatar
Rookie Year: 1994
Originally Posted by Nitroxextreme View Post
My best guess at an application would have to be some sort of cut off valve to lock in a vacuum....seems like a solenoid would also provide the same effect
A good app (IF you get the speed up with servo and/or valve changes, as I suggested above).
Nope, you can't use a kit valve for directly controlling vacuum. If you look at the kit valves specs, they are ALL "piloted". That means they need positive air pressure on their inputs (of several TENS of PSI), just to operate. Therefore, they can only control air going INTO your Vacuum Generator, and the VG must be directly connected to your suction cup. (Which DOES work...)
But if you are intending to generate vacuum with a kit motor, be aware that none of the kit valves are capable of directly controlling vacuum, because even a perfect 14.7 PSI differential across them isn't a sufficient pilot pressure to allow them to operate.
- Keith
Unread 21-01-2007, 01:29
This would be nice to automatically close the valve at the start of the match. We lost 2-3 matches in 2005 from not closing our valve which powered our gripper.
Unread 22-01-2007, 15:48
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Not to rain on anyone's parade..........
This valve's main purpose is to "Dump" air pressure quickly in the event of some emergency (like the main breaker for your pneumatics). If you have this thing embedded in some other device, you obviously will not be able to access it. It's suppost to be located in a place that can be accessed quickly (again, like the main breaker).
Hint:
I would not pass this thing in tech inspection.
Ed Sparks
MECH TECH FRC-3959
Unread 22-01-2007, 16:17
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
Hint:
Ed, if you read the other comments and the description on the picture, you'll see that this mechanism is being used as a valve to operate under a vacuum. I suspect that in order to be legal, they are using another identical valve elsewhere to operate as the "breaker" that you describe. In light of this, I don't see any reason why it wouldn't pass inspection.
2007 Pittsburgh Website Award
Team 1388 - Eagle Robotics
_
Unread 22-01-2007, 19:53
FRC #2363
Will it really work to "lock in" a vacuum seal on the inner tube, or will you have to constantly supply suction to maintain grip?
Unread 22-01-2007, 21:58
DonRotolo's Avatar
Back to humble
FRC #0832
No need to do that, see This Post, COTS stuff that does that exactly. But see Here, too to understand why you might not want to do this.
You need to supply vacuum almost continuously, there is a certain amount of leakage. Also consider how to let it go... But, maybe you want to use a Clippard tank to store vacuum, this'll seal it in.
Don
PC Controlled Robot EHaskins Programming 6 05-11-2006 06:45
pic: pneumatic actuation of ball valve Andrew Schuetze Extra Discussion 2 30-10-2006 08:40
Camera Controlled Robot douglass1371 Programming 1 19-02-2006 19:22
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servos controlled by RC? Obi Programming 5 01-02-2005 14:43
