Go to Post As they say... I'd rather be lucky than good any day (especially Saturdays). :) - JVN [more]
Unread 21-01-2007, 22:53
Cpt_Dave_Lister
Re: pic: Team 948 Shifting Transmission Version #2
Very nice, have you guys built it yet? =)
Unread 21-01-2007, 22:55
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
Working on it - the gears have been ordered at least. The whole gearbox casing (w/ the pneumatic mounting) is only 3 inches thick, the gearbox is around 8 lbs.
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Unread 22-01-2007, 01:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Out or curiosity, did you order gear stock for the gears? And of you did, from where? (See my signature)
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 22-01-2007, 01:23
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
Looks nice,
Are those spacers next to the gears? or the hubs of the gears. If is the hubs I would suggest putting some spacer in between the two gears to reduce friction since they will spin at different ratios.
Just my $0.02
David G.
Team 1251 The Techtigers
Unread 22-01-2007, 08:37
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Looks good! Just remember to give yourself enough time to get the output shaft and gears heat treated.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 22-01-2007, 09:31
AKA: Dave
Why do you say they have to heat treat them. I dont think there is a need, not for FIRST uses. But then again I am not an engineer. Do you mind explaining.
Thanks
David G.
Unread 22-01-2007, 10:55
AKA: Cliff Mock
Rookie Year: 1997
Thanks
David G.
We have always hardened both the output gears and shaft for two main reasons. Hardening both parts means no wear on parts and also reduces the chances of galling. The gears definately will need to be hardened if you plan on shifting under a full load condition. Testing before hardening the slots in the gears that the ball bearing pops into has shown a slight wear pattern. This wear pattern maybe due to just run in and not get any worse during the season however our team likes to have a nearly maintenance free transmission. I know teams who used a ball shifter that did not harden the output shaft or the gears and they had no problems, but we'd rather not have an extra part to keep track of on our machine. Build it simple and fool proof.
Unread 22-01-2007, 12:19
AKA: Dave
I see,
I designed a ball bearing shifter that is currently being tested but i did not take into a count hardening the gears. However I used 6 holes on the gears and 3 balls so there is not as much friction while shifting. But either way do you think you could describe the process for hardening the gears?
I would appreciate it.
Thanks,
David Guzman
Unread 22-01-2007, 12:48
AKA: Cliff Mock
Rookie Year: 1997
David,
We have a local company harden the gears and shaft for us. I don't know much about the process Maybe someone with more mechanical knowledge could explain the process of case hardening.
Unread 22-01-2007, 13:31
in between teams
AKA: Luke Van Oort
Originally Posted by camtunkpa View Post
David,
Dave Lavery made two very informative posts about hardening stuff here and here.
Team 1219: 2009 - Mentor
Unread 22-01-2007, 14:33
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
One inch diameter A2 tool steel is what we make the shaft with. The shaft and gears were hardened to between 55 and 62 Rockwell C.
Whatever you do, just keep them lubricated as with any transmission!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-01-2007, 16:43
EricH EricH is offline
In 2003, we had a gearbox for our four-bar lift. We hit the bar across the field wrong two days before ship at a practice event and broke two teeth on one gear (non-treated). We exchanged it for a heat-treated gear and had no problems later.
Unread 22-01-2007, 19:09
FRC #0948
Looks nice,
Just my $0.02
David G.
Those are 1/16 in spacers.
For the gears, we ordered standard gears from smallparts.com - GSS 1435 and GSS 1460 are the part #s.
-Jake Felser-
Unread 24-01-2007, 20:09
FRC #0948
*bump*
Does anyone have thoughts on using a servo to drive this, without modifying the center spool to include a spring?
-Jake Felser-
Unread 25-01-2007, 08:57
AKA: Cliff Mock
Rookie Year: 1997
*bump*
I pitty the little servo about to die. All joking aside, I think you might run into problems if there is no spring in the system. Remember for a short period of time every time you shift, there will be binding while you're waiting for the balls to line up with the slots in the gear. These transmissions are more friendly than others towards their shifting actuator, but I would seriously suggest having some spring in there. The plunger shaft doesn't have to have springs on it as long as the device actuating the plunger has some sort of shock absortion either in the unit or the connecting linkages.
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing jfelser Extra Discussion 24 18-12-2006 21:18
pic: Team 948 2 speed dog shifter adlai Extra Discussion 3 05-12-2006 07:54
pic: Concentric Shifting Transmission Concept Madison Technical Discussion 9 20-06-2006 21:49
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
