Go to Post In my opinion, I wouldnt want gifts or praise from people about my help to a robotics team, all I would want is a thank you, that would make all my hard work and efforts worth while and it would prove to me that I could actually be making a difference in the students lives - Mike Schroeder [more]
Unread 22-01-2007, 09:31
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
Re: pic: Team 948 Shifting Transmission Version #2
Why do you say they have to heat treat them. I dont think there is a need, not for FIRST uses. But then again I am not an engineer. Do you mind explaining.
Thanks
David G.
Team 1251 The Techtigers
Unread 22-01-2007, 10:55
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Thanks
David G.
We have always hardened both the output gears and shaft for two main reasons. Hardening both parts means no wear on parts and also reduces the chances of galling. The gears definately will need to be hardened if you plan on shifting under a full load condition. Testing before hardening the slots in the gears that the ball bearing pops into has shown a slight wear pattern. This wear pattern maybe due to just run in and not get any worse during the season however our team likes to have a nearly maintenance free transmission. I know teams who used a ball shifter that did not harden the output shaft or the gears and they had no problems, but we'd rather not have an extra part to keep track of on our machine. Build it simple and fool proof.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 22-01-2007, 12:19
AKA: Dave
I see,
I designed a ball bearing shifter that is currently being tested but i did not take into a count hardening the gears. However I used 6 holes on the gears and 3 balls so there is not as much friction while shifting. But either way do you think you could describe the process for hardening the gears?
I would appreciate it.
Thanks,
David Guzman
Unread 22-01-2007, 12:48
AKA: Cliff Mock
Rookie Year: 1997
David,
We have a local company harden the gears and shaft for us. I don't know much about the process Maybe someone with more mechanical knowledge could explain the process of case hardening.
Unread 22-01-2007, 13:31
in between teams
AKA: Luke Van Oort
Originally Posted by camtunkpa View Post
David,
Dave Lavery made two very informative posts about hardening stuff here and here.
Team 1219: 2009 - Mentor
Unread 22-01-2007, 14:33
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
One inch diameter A2 tool steel is what we make the shaft with. The shaft and gears were hardened to between 55 and 62 Rockwell C.
Whatever you do, just keep them lubricated as with any transmission!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-01-2007, 16:43
EricH EricH is offline
In 2003, we had a gearbox for our four-bar lift. We hit the bar across the field wrong two days before ship at a practice event and broke two teeth on one gear (non-treated). We exchanged it for a heat-treated gear and had no problems later.
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing jfelser Extra Discussion 24 18-12-2006 21:18
pic: Team 948 2 speed dog shifter adlai Extra Discussion 3 05-12-2006 07:54
pic: Concentric Shifting Transmission Concept Madison Technical Discussion 9 20-06-2006 21:49
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
