Go to Post I keep on accidently seeing (and pronouncing) it as Chef Deli. - JJG13 [more]
Unread 22-01-2007, 22:34
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: Team 1345's 2007 chassis
Alright, I am going to try to answer everyone’s questions…
Originally Posted by Alex Cormier View Post
Looking good Arefin! Lemme guess, battery will be in the rear? And possible 1/2 robot lift 12".
… wrong.
Originally Posted by Adam Richards View Post
I'm calling arm on gearbox-side, ramp on the back.
… wrong.
Originally Posted by clean399 View Post
seems like it will be a lifting robot not much ground clearance for going up ramps.
We will be going up any ramp that is less than 20 degrees.
Originally Posted by Tim Arnold View Post
/me is scared
You guys haven't yet seen the pushing power of this beast... want to move the goal?
Thanks for your comment Tim. I personally think there will be many other robots that will have pushing power just like this one. If the rule didn’t stop us, we would probably move the goal. =)
Originally Posted by sdcantrell56 View Post
That's the first chassis that looks close to as overbuilt as ours. It's looking pretty good.
I don’t know if I would say overbuilt. It’s was very easy to work with. Thanks to my Canadian friends who gave me this idea to use 4x4 for chassis material.
Originally Posted by David Guzman View Post
Looks good,
What material is the plate on the bottom.
David G.
It’s 1/16” lexan.
Originally Posted by Tytus Gerrish View Post
You need to add some structure to resist that square from turning into a diamond. that piece of plastic all the electrical is mounted to isn’t offering any strength to the frame. also. bumpers are a must because there are moving parts exposed on the outside in the "bumper zone" that according to Murphy’s law will get smashed. as well as the front and rear being made of 1/8" thick c-channel offer little resistance to collapse upon impact. it would be a large benefit to add some central strength members to resist against that
Is it going to collapse? Doesn’t look like it, but it can in a brutal fight in the field. It’s better to add support than being left without a chassis in the middle of the competition. The way the two modules are connected are with the C channels. On the bottom, I am running 1” wide 1/8” thick aluminum across to support the chassis. On top of that… the lexan is mounted (it is mounted on the C channel and the crossbars I am running underneath the chassis).
Originally Posted by Jetgrindradio00 View Post
Nice setup. Looks like the top is exactly 4" of the ground. I wonder why?
… we will be picking up robot/robots off the ground 12”.
Originally Posted by Conor Ryan View Post
Questions for the nicest looking chassis and drive train in awhile (I haven't seen Tytus's waterjetted one yet)
  • How big are your drive sprockets coming out of the AM Shifters (not the ones built in, but the ones attached to the wheels)?
  • Live or Dead Axles?
  • Are your axles running on bushings or bearings?
  • What is your base plate? Wood?
Keep up the great work 1345!
1) It’s 28 tooth.
2) Dead axles.
3) There are bearings on the wheels.
4) There is no such thing as “base plate” on this chassis. Electronics are mounted on a 1/16” lexan which is mounted on the crossbars and C channels.
Thanks Conor, looking forward to see your robot in action this season. Tytus’s chassis looks great. His chassis looks unstoppable just like it was in 2005, I only hope his driver can drive that thing.
Originally Posted by Ryan Dognaux View Post
So are the wheels near the battery powered at all? Interesting placement of your gearboxes there. I want to see some video of this in action asap Arefin
All the wheels are powered. There is single chain running each module. Video will be posted soon.
Originally Posted by Chris Fultz View Post
Arefin,
it appears you are using that messsy coil of tubing to provide extra air accumulation, a clear rules violation if i ever saw one. i am disappointed in you and may volunteer to be an inspector at one of your regionals just so I can DQ you.
ps - please volunteer for the iri so i can make you in charge of cleaning up trash as punishment for poor behavior.
(cool chassis, anyway)
pictures can be decieving. There are no extra tubing in that chassis. It looks that way, because most of the stuff weren't zip tied down well enough. The electrical board needs a lot of work. It will be clean once the whole robot is together. Your inspectors won’t have any trouble inspecting that thing, since we are talking about making our way up to Indiana this summer.
Volunteer? Hmm… we shall see. It all depends on if team is going up there or not or if I am taking classes over the summer or not.
pic: FRC488 2007 Chassis Madison Extra Discussion 16 22-01-2007 18:51
pic: Team 1345's wheel Arefin Bari Extra Discussion 14 11-01-2007 20:23
pic: 1345's Cart Arefin Bari Extra Discussion 12 04-03-2006 09:56
pic: 1345's Control Box nehalita Robot Showcase 4 23-02-2006 18:08
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
